    Is P is also a reserved macro param letter?
    • zaptaundefined
      zapta
      The macro parameters documentations says " do not use G, M, N or T as parameters" so I used P but it also doesn't seem to work.
      In macro.g
      echo {param.P}
      And then invoking using the command line which results in the error: unknown parameter 'P'.
      M98 P"macro.g" P100
      Is P also a reserved param letter?
      (I am using RepRapFirmware for Duet 3 Mini 5+ 3.4.0beta5 (2021-10-12))
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @zapta
        @zapta
        The P parameter is not accessible from within the macro.
        The reason I was given was that it's assumed we already know the name of the macro we are running.
        https://forum.duet3d.com/topic/22731/param-p-doesn-t-return-macro-name?_=1644101120714
        I think it would be handy to be able to parse the currently running macro, but effort vs return probably doesn't cut it with the other developments in the works.
        zaptaundefined 1 Reply Last reply Reply Quote 0
        • zaptaundefined
          zapta @OwenD
          Thanks @owend. In that case, may be useful to update the documentation, adding it to the list of 'problematic' macro parameters. Took me some time to figure this out.
