3HC sensorless homing
It is possible to use sensorless homing on 3HC board? I'm currently using 6HC + 1LC and I want to add some more axes. 3HC is the ideal solution for me.
Thanks
ping for visibility....
3HC arrived yesterday so I can test it. Unfortunately, I was unable to commission sensorless homing. If I connect the U axis directly to the 6HC board it works without problems. As soon as I switch it to 3HC, I can't get sensorless up and running. I am doing something wrong?
G28 U
Error: Homing failedAll boards on 3.4 rc1
m122 b1 Diagnostics for board 1: Duet EXP3HC firmware version 3.4.0rc1 (2022-02-08 09:04:27) Bootloader ID: SAME5x bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 158948, free system stack 177 words Tasks: Move(notifyWait,0.0%,126) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.8%,65) MAIN(running,90.8%,410) IDLE(ready,0.0%,39) AIN(delaying,1.3%,263), total 100.0% Last reset 00:00:41 ago, cause: power up Last software reset data not available Driver 0: pos -127200, 200.0 steps/mm,standstill, SG min 0, mspos 520, reads 35298, writes 5 timeouts 0, steps req 129200 done 129200 Driver 1: pos 0, 80.0 steps/mm,standstill, SG min n/a, mspos 8, reads 35303, writes 0 timeouts 0, steps req 0 done 0 Driver 2: pos 0, 80.0 steps/mm,standstill, SG min n/a, mspos 8, reads 35302, writes 0 timeouts 0, steps req 0 done 0 Moves scheduled 3, completed 3, in progress 0, hiccups 0, step errors 0, maxPrep 24, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -2/5, peak Rx sync delay 180, resyncs 0/0, no step interrupt scheduled VIN voltage: min 26.3, current 26.3, max 26.3 V12 voltage: min 12.3, current 12.3, max 12.3 MCU temperature: min 32.0C, current 33.1C, max 33.1C Last sensors broadcast 0x00000000 found 0 89 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 243, send timeouts 0, received 357, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 295, adv 37055/37184
; General preferences M81 C"pson" G4 S1 M80 ;M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"malej" ; set printer name ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network ;M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP ;M586 P0 S1 ; enable HTTP ;M586 P1 S0 ; disable FTP ;M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes forwards M569 P0.3 S0 M569 P1.0 S0 ;;;;;;;;;;;;;;;;;;;;;;; ; physical drive 0.2 goes forwards M569 P121.0 S1 ; physical drive 121.0 goes forwards M584 X0.0 Y0.1 Z0.2:0.3 E121.0 U1.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z400.00 E420.00 U200 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E150.00 U500 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z2000.00 E7500.00 U12000 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z300.00 E5000.00 U1500 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E450 I30 U1200 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M671 X26:240 Y105:105 S10 ; position of Z axis motors ; Axis Limits M208 X0 Y0 Z0 S1 U0 ; set axis minima M208 X250 Y210 Z215 S0 U300 ; set axis maxima ; Endstops M574 X1 S3 ; configure sensorless endstop for low end on X M574 Y1 S3 ; configure sensorless endstop for low end on Y M574 U1 S3 ;;;;;;;;;;;;;;;;;;;;;;;;;; M574 Z1 S2 ; configure Z-probe endstop for low end on Z M915 X Y R0 F0 H400 S0 M915 U R0 F0 H200 S2 ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^121.io0.in" H4 F400 T18000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X26 Y0 Z1.55 ; set Z probe trigger value, offset and trigger height M557 X30:250 Y0:210 S35:30 ; define mesh grid ; Filament sensor M591 D0 P3 C"121.io1.in" S1 R50:200 L25 E10.0 ; MFM config ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" Q10 T0 ; create bed heater output on out0 and map it to sensor 0 ;M307 H0 B0 R0.161 C1877.2 D21.70 S1.00 V24.9 ; disable bang-bang mode, set PWM limit M307 H0 B0 R0.311 C426.5 D10.90 S1.00 V26.1 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"121.temp0" Y"thermistor" T100000 B4680 C6.455513e-8 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"121.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 R3.267 C128.6:76.4 D4.80 S1.00 V25.9 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ;Sensors M308 S10 Y"drivers" A"6HC-drivers" M308 S11 Y"mcu-temp" P"121.dummy" A"1LC temp" M308 S12 Y"drivers" P"121.dummy" A"1LC driver" ;CPU temperature calib M912 P0 S-20 ; Fans M950 F0 C"121.out1" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out2+out2.tach" ; Q500 ;M950 F1 C"121.out2+121.out2.tach" ; create fan 1 on pin out4 and set its frequency + snimaní otáček M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"Mosquito" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M150 X1 Q3000000 ; NEOPIXEL M150 U120 S15 ; NEOPIXEL M955 P121.0 I42 ; specify orientation of accelerometer on SAMMYC21 with CAN address 121 if !exists(global.beepbeep1) || global.beepbeep1=null global beepbeep1=0 else set global.beepbeep1=0 if !exists(global.fantmr1) || global.fantmr1=null global fantmr1=0 else set global.fantmr1=0 if !exists(global.endtemp1) || global.endtemp1=null global endtemp1=0 else set global.endtemp1=0 if !exists(global.tiktak1) || global.tiktak1=null global tiktak1=0 else set global.tiktak1=0 if !exists(global.fuufuu1) || global.fuufuu1=null global fuufuu1=0 else set global.fuufuu1=0 ; Miscellaneous T0 ; select first tool
Thanks for any help.
@petrkroupa sensorless homing is not yet supported on CAN-connected expansion boards. I expect to implement this in RRF 3.5. Please see the list of limitations on the wiki. https://docs.duet3d.com/User_manual/RepRapFirmware/CAN_limitations
@dc42 - Thanks for the clarification. I was hoping that this feature will be in 3.4. It is true that 3.4 brings a lot of other new things. Good work!
Looking forward to the 3.5 release as I have just run into this issue. I had a quick look in the 3.5-dev branch commit history on Github and couldn't see anything as yet. Happy to help test any RC's once they're available. Thanks!
Good afternoon, can you tell me if you managed to solve this problem? Did you end up using the limit switches on additional axes or did you change the board / firmware / find another way?
