    [3.4b7] Total layers in DWC issue
    Beta Firmware
    • oozeBotundefined
      oozeBot
      Total layer count in DWC appears to be one less than actual. See screenshot. We can provide gCode if needed. The model was 20mm tall with .5mm layer height, so it definitely has 40 layers.
      FYI - we are using 6HC and SBCs - not sure if it's related.
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @oozeBot
        @oozebot When you print a purge line with e.g. 0.3mm layer height and then the first layer with e.g. 0.2mm layer height, then dwc calculate them as 2 layers.
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @cosmowave
          @cosmowave That does not appear related to what we are reporting. We printed a file that has 40 layers. DWC reports it as having 39 total.
          • oozeBotundefined oozeBot marked this topic as a question
            Can you share the gcode file?
            • oozeBotundefined
              oozeBot @Phaedrux
              @phaedrux - Here you go. Thanks
              xyzCalibration_cube 0.6mm nozzle - 20mm.gcode
              • oozeBotundefined oozeBot referenced this topic
                I wonder if it just doesn't catch the first layer change because it doesn't have a leading 0
                G1 Z.5 F6000
