    issues in RRF build
    Firmware developers
    541
    • user M_123undefined
      user M_123
      I am build RRF3.4beta5 in eclipse it showing error which is
      "Program "arm-none-eabi-g++" not found in PATH
      Program "make" not found in PATH"
      JoergS5undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @user M_123
        @user-m_123 please check the documentation https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware
        Your problems are that the GNU Arm tools and the make are not installed and/or not in the path to be found. arm-none... are the GNU ARM toolchain 8 2018 q4, the make is a special version to handle long command lines. After installing and adding to path, Eclipse must be restarted to be effective.
        user M_123undefined 1 Reply Last reply Reply Quote 0
          user M_123 @JoergS5
          @joergs5 it's installed
          JoergS5undefined user M_123undefined 2 Replies Last reply Reply Quote 0
          • JoergS5undefined
            JoergS5 @user M_123
            @user-m_123 if you open a command line with calling cmd and say arm-none-eabi-g++, does it find the program? The same with make?
              user M_123 @user M_123
              JoergS5undefined 1 Reply Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @user M_123
                @user-m_123 it must be also in the path. And the version is newer than the version 8 2018 q4 which I'm using. I don't know whether 10 2020 q4 is compatible.
                  user M_123 @JoergS5
                  @joergs5 yes it is
                    • JoergS5undefined
                      JoergS5 @user M_123
                      @user-m_123 did you check calling the program from commandline?
                      eg
                      C:\Users\Joerg>arm-none-eabi-g++ --version
                      arm-none-eabi-g++ (GNU Tools for Arm Embedded Processors 8-2018-q4-major) 8.2.1 20181213 (release) [gcc-8-branch revision 267074]
                      Copyright (C) 2018 Free Software Foundation, Inc.
                      This is free software; see the source for copying conditions. There is NO
                      warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                      C:\Users\Joerg>make --version
                      GNU Make 4.1
                      Built for x86_64-w64-mingw32
                      Copyright (C) 1988-2014 Free Software Foundation, Inc.
                      License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
                      This is free software: you are free to change and redistribute it.
                      There is NO WARRANTY, to the extent permitted by law.
                        dc42 administrators @user M_123
                        @user-m_123 are you building under Windows or under Linux?
                          user M_123 @dc42
                          @dc42 Windows
                            user M_123 @JoergS5
                            @joergs5 Thanks for your support it is build perfectly
                            • JoergS5undefined
                              JoergS5 @user M_123
                              @user-m_123 that's fine, don't hesitate to ask when there is a new question.
                                @user-m_123 from https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware:
                                The build depends on the Eclipse workspace variable ArmGccPath being set to the directory where your arm-none-eabi-g++ compiler resides. For example C:\Program Files (x86)\GNU Tools ARM Embedded\7 2018-q2-update\bin on Windows (see step #1 for which compiler to use). To set it, go to Windows -> Preferences -> C/C++ -> Build -> Build Variables and click "Add..."
                                It sounds to me that you didn't do that step. The Eclipse project is set up so that Eclipse uses that variable to find the compiler.
                                • Phaedruxundefined Phaedrux moved this topic from Firmware installation
