Solved Duet 2 Wifi MAX31865 bad response
I've connected a generic MAX31865 board to the spi0 header on my duet wifi but it fails to initialise.
It's connected like this post
When I run
M308 S1 P"spi.cs1" Y"rtd-max31865" R430
it returns "Error: M308: Failed to initialise RTD: bad response from sensor"
I've tried cs1 and cs3 but neither will work. Is there a way to troubleshoot the connection?
What firmware version?
@phaedrux 3.3
Do you have more specifics on the generic board?
@jphilly said in Duet 2 Wifi MAX31865 bad response:
It's one of the adafruit clones like this with a 430ohm ref resistor
How have you got it connect to the Duet?
My wires are about 4in long. 3v3 is connected, vin is not
Well it seems like the plastic mount I had the board on was somehow shorting it out. Moved the board around/put it on 30mm of standoffs and it kept working as long as it wasn't touching the mount.
@jphilly I'm glad you solved it.
