BLTouch not working
@diy-o-sphere said in BLTouch not working:
@hsverre
Only with big 5v fans....I dont have any 5 V fan
@hsverre
Set the jumper that way.Now i have set the jumper that way and 2.6 V (half of 5?) at thw PWM
@hsverre
You cannot measure this exactly with a voltmeter. But it could be plausible for an end position. It's been a few years since I've measured that too.....I would give it a try. -
The BLTouch still dont work with the 2.6 v. In my opinion the problem is that the PWM gives 2.6 V and not 5 V. The schematics says 5 V and then I should measure 5 V at that pin.
undefined droftarts referenced this topic
undefined hsverre referenced this topic
You can source 5v from other points on the Duex for testing purposes.
https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams
Another possible test would be to disconnect the Duex Ribbon cable and connect the BLtouch wires as shown for a simple Duet connection. If the BLTouch works there, then we have isolated the problem to the Duex itself.
