    Issue after updating RRF 3.1.1 to RRF 3.3.0
    Firmware installation
    290
    • Morane_3803undefined
      Morane_3803
      Yesterday I have my Duet 2 Wifi updated to RFF 3.3.0.
      So far so good. After restarting I got no Tools on my DWC and neither on my PanelDue 7" (firmware 1.17)
      I cannot localize where ther would be anithing wrong with config.g
      Has anyone some input, what could be wrong?
      Thanks a lot
      and regards
      Martin
      Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Jan 03 2021 11:36:26 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"Martins CoreXY" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      ; M587 S"(deleted)" P"(deleted)"
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P3 S1 ; physical drive 3 goes backwards
      M569 P4 S1 ; physical drive 4 goes backwards
      M569 P5 S1 ; physical drive 5 goes backwards
      M569 P6 S1 ; physical drive 6 goes forwards
      M569 P7 S1 ; physical drive 7 goes forwards
      M569 P8 S1 ; physical drive 8 goes forwards
      M569 P9 S0 ; physical drive 9 goes forwards
      M584 X0 Y1 Z2:8:9 E3:4:5: ; set drive mapping :6:7:8:9
      M671 X178:0:280 Y0:315:315 s5
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation:16:16:16:16
      M92 X80.00 Y80.00 Z640.00 E418.50:418.50:418.50 ; set steps per mm:418.50:418.50:418.5
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min):120.00:120.00:120.00:12
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00 ; set maximum speeds (mm/min):1200.00:1200.00:1200.00
      M201 X500.00 Y500.00 Z250.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2):250.00:250.00:250.00:250.00
      M906 X800 Y800 Z800 E800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X340 Y285 Z380 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"duex.e6heat" ; create servo pin 0 for BLTouch
      G31 P500 X54.78 Y0 Z1.65 ; set Z probe trigger value, offset and trigger height
      M557 X60:321 Y10:271 S87 ; define mesh grid
      M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bed_heat" T0 ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 R0.524 C443.4 D3.90 S1.00 B1 ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; R395 und F50 entfernt
      M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      ; M307 H1 R2.400 C92.3 D6.80 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit
      ;M307 H1 R2.191 C226.5:219.1 D7.32 S1.00 V24.1
      ;M143 H1 S280 ; set temperature limit for heater 1 to 280C
      ;M308 S2 P"spi.cs2" Y"rtd-max31865" ; R395 und F50 entfernt
      ;M950 H2 C"e1_heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 R2.663 C208.6 D6.60 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M950 F1 C"fan1" Q500 ; create fan 0 on pin fan0 and set its frequency
      M106 P1 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
      M106 P2 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on
      M950 F0 C"fan0" Q500 ; create fan 2 on pin duex.fan8 and set its frequency
      M563 P0 S"T1" D0 H1 F0 ; define tool 0
      G10 P0 R140 S200 ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"T2" D1 H1 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R140 S200 ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 S"T3" D2 H1 F0 ; define tool 2
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R140 S200 ; set initial tool 2 active and standby temperatures to 0C
      ;M563 P3 S"T4" D3 H2 F-1 ; define tool 3
      ;G10 P3 X31.19 Y0 Z0 ; set tool 3 axis offsets
      ;G10 P3 R140 S200 ; set initial tool 3 active and standby temperatures to 0C
      ;M563 P4 S"T5" D4 H2 F-1 ; define tool 4
      ;G10 P4 X31.19 Y0 Z0 ; set tool 4 axis offsets
      ;G10 P4 R140 S200 ; set initial tool 4 active and standby temperatures to 0C
      ;M563 P5 S"T6" D5 H2 F-1 ; define tool 5
      ;G10 P5 X31.19 Y0 Z0 ; set tool 5 axis offsets
      ;G10 P5 R140 S200 ; set initial tool 5 active and standby temperatures to 0C
      Phaedruxundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @Morane_3803
        @morane_3803 said in Issue after updating RRF 3.1.1 to RRF 3.3.0:
        Update your paneldue firmware to 3.4
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
        Morane_3803undefined 1 Reply Last reply Reply Quote 0
        • jumpedwithbothfeetundefined
          jumpedwithbothfeet @Morane_3803
          M587
          you need to edit your post and remove M587 🙂
          6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
            Morane_3803 @Phaedrux
            @phaedrux
            Thanks, yes I will do so soon. Hope it will help
              Morane_3803 @jumpedwithbothfeet
              @jumpedwithbothfeet
              M587 is not active (;), so this would not help. I guess!
              droftartsundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                droftarts administrators @Morane_3803
                @morane_3803 Does sending M98 P"config.g" show any errors?
                  Morane_3803 @droftarts
                  @droftarts
                  Thanks, checked it and have found some error, now after updating PanelDue as well, eberything works now.
                  Thanks to all of you guys
                  Regards
                  Martin
                  • dc42undefined dc42 marked this topic as a question
                    @morane_3803 it was more....I can see your password etc as opposed to helping with your fault 🙂
                      dc42 administrators @jumpedwithbothfeet
                      @jumpedwithbothfeet I've used admin privileges to delete the SSID and password form the original message.
