    Duex5 issues with fan
    • incurioundefined
      incurio
      I bought a replacement Duex5 board because my current boards part cooling fan was not working for P6 slot. ( order #79384 )
      When I installed the new Duex5 , P2,P4 and P6 fan were working fine but not P8. After some measuring on why new board was having an issue on different fan slot -- I noticed that the there was some burnt material near the P8 slot see attached.
      The current Duex5 I have v0.10 with part cooling fan issue doesnt have any burn marks any where.
      • Phaedruxundefined Phaedrux referenced this topic
        Was there a fan plugged into that port?
        Is it possible bad wiring on a fan has caused the damage? Does the non-working fan from before match up with the one now? Or unrelated?
        incurioundefined 3 Replies Last reply Reply Quote 0
        • incurioundefined
          incurio @Phaedrux
          @phaedrux
          There was a fan plugged into that slot and it does power up when I use a separate power supply providing 24v and 0.1A power. I removed that fan so the damage could be seen easily.
          Is there a brand of fan that is not supposed to be used by these boards?
          All my part cooling fans for my 4 tool changers are using the same model of fan.
          Thx
          • incurioundefined
            incurio @Phaedrux
            @phaedrux I forgot to add in addition to testing using a separate 24v power source.
            I also plugged in the fan for P8 which was not working into P4 slot, then picked up tool 2 to see if it worked, which it did.
            thx
            • incurioundefined
              incurio @Phaedrux
              @phaedrux Hi, the store I bought this product is asking me to get approval from some one in your team to get a refund for this product.
              I am using the same fans on other fan slots with no issues. The same fan that is not powering up on P8 is working fine from both a secondary power supply.
              Please Advise,
              thx
                Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
