    Wiring SuperPinda Z Probe & Microswitch XY Endstops Duet 3
    1.8k
    • davehundefined
      daveh
      I am wiring up my Duet 3 Mini 5+ and just want to double-check some information.
      I have microswitch X and Y end stops. I've connected to the outside terminals NC ends of the switch, I assume these switches must connect to the 5V_EXT and ioN.in pin of one of the IO_N terminals.
      As for the Z Probe, I have an inductive probe. It's got Brown, Blue and Black wires. It's a Super Pinda probe from Prusa and I believe this is the data sheet (it has the pepperl-fuchs on the label). On the datasheet there's this diagram:
      I guess that means BN = BrowN, BK = BlacK and BU is BlUe
      Which pins do they go to? My guess would be Brown 5V, Black ioN.in and Blue GND
      Has anyone else had success with this probe?
      • Gixxerfastundefined
        Gixxerfast
        Microswitches are usually connected ground to io.in and as nc.
        Read this https://duet3d.dozuki.com/Wiki/M574#Section_M574_RepRapFirmware_Num_3 for more info
        Regarding the Superpinda, I have one on front of me now connected to my breadboard.
        Yes, Brown is +5V and Blue is -V. Black is signal and output 5V when close to metal. You need a steel surface to trigger against. It will not react on aluminium.
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
        • davehundefined
          daveh
          Thanks.
          I looked at the configurator and see there are many options:
          I guess you can do either unless I misunderstand what these options mean.
          • davehundefined
            daveh
            Aha! Reading this Ender 3 Pro Guide I now see why you'd want to do it that way.
            I notice that IO5/6 only have 3 pins so the other inputs are more versatile.
            I must admit, the docs are difficult to follow! This Ender 3 guide contradicts the wiring guide which says IO 0-4 are for endstops and mentions nothing on IO 5 & 6.
              Phaedrux Moderator @daveh
              @daveh said in Wiring SuperPinda Z Probe & Microswitch XY Endstops Duet 3:
              I'll add a note to io5 and 6 to explicitly say endstops. However, one of the main features of the Duet 3 is the versatile nature of the IO ports compared to having dedicated ports for specific hardware. The only differentiating thing between 5&6 and the rest is tha lack of PWM output, so literally perfect for simple endstops.
