    How to check the real current of the stepper motor
    2.6k
    • moth4017undefined
      moth4017 @moth4017
      @moth4017 said in How to check the real current of the stepper motor:
      @zapta its ok used you first macro
      M906 600 measured max 0.5179mA
      M906 1000 Measured max 0.6414mA
      i tried to test the extruder but couldn't get to extrude for some reason
      values in Amps not mA
        @moth4017 bear in mind that when the stepper driver is moving slowly, standstill current reduction will kick in.
        zaptaundefined 1 Reply Last reply Reply Quote 0
        • zaptaundefined
          zapta @dc42
          Thanks @dc42. A couple of questions if you don't mind. Having a simple technique to measure actual current would be very useful.
          1. The code that @moth4017 used moves 0.001mm every 250ms. Will this kick in the standstill current?
          2. What about the code below, will it kick in the standstill current?
          G1 X100 Y100 ; move to starting point
          M203 I1      ; allow slow movements
          G1 X103 F1   ; move both motors slowly, corexy version
          1. Any suggestion for a reliable way to measure the actual current using simple means?
            dc42 administrators @zapta
            @zapta on the TMC2209, standstill will kick in when the frequency of step pulses is less than approx. 12Hz. So the axis speed below which standstill current reduction kicks in depends on your steps/mm. For example, if you have 100 steps/mm, then 12Hz corresponds to 12/100 mm/sec = 0.12mm/sec = 7.2mm/min.
            When measuring motor current you can use M917 to set the standstill current to 100% of the running current for a particular axis. At high currents, on the MB6HC and EXP3HC RRF will impose a maximum standstill current below 100%, but this doesn't apply to the Duet 3 Mini.
            zaptaundefined moth4017undefined 2 Replies Last reply Reply Quote 0
            • zaptaundefined
              zapta @dc42
              Thanks @dc42. I updated the macro to disable standstill current reduction and am getting now very consistent current readings, peaking at ~1250ma with 1200ma configuration (good). This is with a Mini 5.
              G1 X100 Y100   ; Starting location
              M203 I1        ; Allow very slow movements
              M917 X100 Y100 ; Disable standstill current reduction.
              G1 X103 F1     ; Move slowly. Moves both motors with coreXY
              I also ordered this +/-2A meter, may be more visual https://www.aliexpress.com/item/32400650799.html
              • moth4017undefined
                moth4017
                @zapta
                M1000 requested measures 0.8379A with you new script
                • moth4017undefined
                  moth4017 @dc42
                  @zapta
                  ive deleted the macro that contained
                  ; Move slowly to identify peak stepper current.
                  ; Assuming XY are already homed.
                  G90 ; absolute positioning
                  G1 X100, Y100 ; starting point
                  G91 ; relative positioning
                  while iterations < 500
                  echo "Iteration " ^ {iterations}
                  ;G1 X0.001 Y0.001 ; for cartesian printer
                  G1 X0.001 ; for core XY printer
                  G4 P250 ; Wait 250ms
                  but it is still continuously running , where would it be hiding so i can stop it 🙂
                  • zaptaundefined
                    zapta @moth4017
                    It should stop after a minute or two. What I do is pressing on the red STOP button on PanelDue or DWC to reset the machine. This also resets any configuration changes the script may do.
                    • zaptaundefined
                      zapta @moth4017
                      I guess it's now a question to the Duet team, is this a reliable measurement and is the result within the expected range.
                        @zapta I would expect it to be closer than that, it should be less than 10% out.
                        moth4017undefined 1 Reply Last reply Reply Quote 0
                        • moth4017undefined
                          moth4017 @dc42
                          @dc42 so where does this leave us? is it lower that it should be or within acceptable parameter's
                          • moth4017undefined
                            moth4017 @moth4017
                            @moth4017 i tried the current measure on the extruder not using the script but setting the extrude speed to 0.001mm/s the highest reading i got was 0.1347A
                            m906
                            Motor current (mA) - X:1000, Y:1000, Z:600, E:1200, idle factor 30%
                            PM M913
                            Motor current % of normal - X:100, Y:100, Z:100, E:100
                            • zaptaundefined
                              zapta @moth4017
                              @moth4017, as reported in a previous post, I got X current that seems to be in range so I am trying to identify differences from your configuration.
                              1. I was measuring an X current on a motor that is connected to the daughter board. [theoretically it should behave exactly like a main board driver since it has direct connection]
                              2. This is by firmware configuration. It's an older firmware version than yours.
                              RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta5 (2021-10-12 13:53:24) running on Duet 3 Mini5plus WiFi (standalone mode)
                              Board ID: A0L0Y-5296U-D65J0-40KMN-0W03Z-HBTQS
                              1. [long shot in the dark] The Mini 5 uses on board current sense resistors so theoretically if the value is in connect or a connection is not good, it may increase the actual current without the drive being aware of it.
                              Not sure if it helps. 😉
                              • moth4017undefined
                                moth4017 @zapta
                                @zapta i notie there is a vref on the tmc do you know if this value changes when controlled by the miro ,
                                • zaptaundefined
                                  zapta @moth4017
                                  @moth4017, I am not an expert, but you can try searching the driver's datasheet for 'vref' and 'sense' and see if it helps. It's a smart chip so there are all kind of programming options for the RRF firmware to use.
                                  https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2209_Datasheet_V103.pdf
                                  The schematic of the Mini 5 suggests that it uses 56 milliohms resistors for sensing the coil currents.
                                    @zapta correct, the sense resistor is 0.056 ohms.
                                    There are a few factors that may cause the current to be inaccurate:
                                    • The internal resistance of the BRA and BRB pins needs to be taken into account. We assume this is 0.02 ohms, as specified on the datasheet.
                                    • The driver reference voltage has a tolerance of +/- 5%
                                    • The current will be rounded to the nearest multiple of approx. 74mA, usually down (up only if the next multiple is really close). This means that if you set 1000mA then the current setting requested from the driver will be 962mA.
                                    • moth4017undefined
                                      moth4017 @dc42
                                      @dc42 My BRA andBRB are 0.056ohms
