Extruder reporting 2000C
@moth4017 Check your cable crimp connectors and thermistor
@moth4017 said in Extruder reporting 2000C:
just cam back to my printer while in idle the Extruder was reporting the hot end at 2000 C,
nit sure why , but just thought ill let you no, buy the way the actual extruder was at room temperature
What board and which firmware? Also which temperature sensor? My PT100 pretty much failed shortly after switching to 3.4 RC1 - coincidence or symptom?
Duet3 + Mini 5 , thermistor in the heat block , all connections are ok just done another print all ok
@moth4017
just happend againg , i will see if i can track it down
