    Diagnosing Thermistor/Hotend Problems after vanishing config.g
    • daveh
      daveh last edited by
      I'm running a Duet 3 Mini 5+ with Mosquito and Slice 300 deg thermistor. Still setting up, yet to print anything
      Yesterday, I got most stuff set up, did PID calibration and it seemed like it was working fine. I didn't check the actual temp when set to 240 but it did seem hot
      Today, I turned on and config.g and config.g.bak had vanished! I'd yet to back it up 😞
      I've spent quite some time today repeating the process but now I can't get my hotend to work. I setup the thermistor with the standard values on the slice page, T100000 B4680 C6.455513e-8
      It's reading correctly at room temp but as temperature rises, it's going up far too quickly and consequently the pid process fails.
      I managed the setup the bed no problem PID worked correctly, I used an IR thermometer to check the surface and it seems to be correct within a degree of the bed thermistor
      It doesn't seem like the hotend is giving the correct value, approx 70deg despite reading 190ish via the thermistor
      I assume the problem is in my config as it was working yesterday (though maybe it's something - any ideas what I might have got wrong?
      • daveh
        daveh last edited by daveh
        It seems was the part cooling fan. It dramatically slowed down the heating to the point where tuning fails. Also even though it says "turning off fans" it doesn't seem to.
        After tuning, If I turn the fan on when it's up to temp it drops a few degrees but remains largely stable.
          @daveh said in Diagnosing Thermistor/Hotend Problems after vanishing config.g:
          Sorry to hear about that. We haven't seen that problem crop up in quite a while. And now today I see it has happened twice.
          When and where did you purchase the Duet?
          As for your hotend tuning problem, what tuning command are you using? M303 H1 S250 or M303 T0 S250? H1 tunes it as a heater, but T0 will tune it has a tool, and will use the fan to predict how much it will cool. The message about the fan running but not actually running may be a display message error. What firmware version are you using?
          daveh 1 Reply Last reply Reply Quote 0
          • daveh
            daveh @Phaedrux last edited by daveh
            @phaedrux thanks for the response
            The file disappear has happened again today. I know exactly what I did this time, I hit the emergency stop button on DWC and it didn't come back after. I wanted to interrupt a job that had essentially crashed the head. I think I likely pressed the reset button a couple of times but that didn't do anything. I didn't hold it long.
            I was using the H1 command. I used the configurator for the initial setup just yesterday and it took whatever it provided yesterday.
            I did back up the file config.g this time and used m500 to capture the tuning so hopefully I won't need to do the tuning again.
            I bought the Duet some time ago and only got around to setting it up. E3D on 17th August. Despite the problems, I like it a lot and I bought another one!
            I've seen it said in other threads it could be the SD card, I can try another... but I find it unlikely given that it's specific two files.
              Can you post the results of M122?
              • daveh
                @phaedrux
                	m122
                RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
                Board ID: PM5VB-1396U-D65J0-40KMS-LU03Z-70KGZ
                Used output buffers: 3 of 40 (11 max)
                Static ram: 102724
                Dynamic ram: 106088 of which 0 recycled
                Never used RAM 34892, free system stack 202 words
                Tasks: NETWORK(ready,14.5%,222) HEAT(notifyWait,0.0%,366) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,0.7%,115) MAIN(running,83.8%,412) IDLE(ready,0.2%,29) AIN(delaying,0.8%,273), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:03:02 ago, cause: power up
                Last software reset at 2022-02-22 17:12, reason: User, GCodes spinning, available RAM 32004, slot 0
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                MCU revision 3, ADC conversions started 182848, completed 182848, timed out 0, errs 0
                Step timer max interval 1290
                MCU temperature: min 17.2, current 26.6, max 26.6
                Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 9585, writes 9, timeouts 0, DMA errors 0
                Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 9585, writes 9, timeouts 0, DMA errors 0
                Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 9585, writes 9, timeouts 0, DMA errors 0
                Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 9584, writes 9, timeouts 0, DMA errors 0
                Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 9585, writes 9, timeouts 0, DMA errors 0
                Driver 5: position 0, assumed not present
                Driver 6: position 0, assumed not present
                Date/time: 2022-02-23 08:43:06
                Cache data hit count 342335557
                Slowest loop: 13.38ms; fastest: 0.12ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 3.4ms, write time 0.0ms, max retries 0
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters = 0 -1, chamberHeaters = -1 -1
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty.
                === CAN ===
                Messages queued 1642, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 914/0/0
                Tx timeouts 0,0,913,0,0,727 last cancelled message type 30 dest 127
                === Network ===
                Slowest loop: 12.85ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is active
                WiFi firmware version 1.26
                WiFi MAC address d8:bf:c0:14:e6:c3
                WiFi Vcc 3.36, reset reason Power up
                WiFi flash size 2097152, free heap 25200
                WiFi IP address 192.168.86.38
                WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
                  Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
