    MotionWebcamServer plugin - Missing library
    Beta Firmware
    1.8k
    • chrishammundefined
      chrishamm administrators @MintyTrebor
      @mintytrebor DWC lets you show the same content on the Jobs -> Webcam page if you check Embed webcam image in an iframe on the Settings -> General page and change the config + URL accordingly.
      PS: I'm rebuilding DuetPi to make the required changes from above obsolete. The next DSF version will fix it, too.
      Duet software engineer
      MintyTreborundefined 1 Reply Last reply Reply Quote 1
      • MintyTreborundefined
        MintyTrebor @chrishamm
        @chrishamm said in MotionWebcamServer plugin - Missing library:
        Great. Thanks @chrishamm
        NodeDSF - Native Node-Red integration with Duet boards.
        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
        ReleaseMgr - Duet update info inside DWC.
        Repo
        • luckyflyerundefined
          luckyflyer
          @chrishamm, @MintyTrebor Thanks
            luckyflyer
            @chrishamm @MintyTrebor I would like to increase the frame rate. Could you help a Linux dummy out and give me the exact command to enter to change the frame rate. Thanks
            adammhaileundefined 1 Reply Last reply Reply Quote 0
            • adammhaileundefined
              adammhaile @luckyflyer
              @luckyflyer said in MotionWebcamServer plugin - Missing library:
              In with your system files is now motion.conf. Open that file to edit in DWC and go to around line 59 and change the default 15 to whatever you want (within limits of your camera, of course). It'll look like this:
              # Maximum number of frames to be captured per second.
              framerate 15
              luckyflyerundefined 1 Reply Last reply Reply Quote 0
                luckyflyer @adammhaile
                @adammhaile Wow that was too easy, thanks @adammhaile
                  luckyflyer
                  This post is deleted!
                  • Phaedruxundefined Phaedrux referenced this topic
                    adammhaile @MintyTrebor
                    @mintytrebor Are you aware of any way to get motion to output a stream larger than 640x480?
                    I've tried updating motion.conf but no matter what size I set the stream stays tiny.
                    MintyTreborundefined 1 Reply Last reply Reply Quote 0
                      MintyTrebor @adammhaile
                      @adammhaile
                      My Config:
                      motion.conf.txt
                      I also made sure to use a resolution supported by my camera by checking:
                      v4l2-ctl --list-formats-ext
                      more info https://www.mankier.com/1/v4l2-ctl
                      Repo
