    Interpreting accelerometer result
    • claustro
      claustro last edited by claustro
      Hi all ,
      I installed a LIS3DH ( waiting for a LIS3SDH ) on my DBOT corexy style printer
      this is my first result running G1 X-50 G4 S2 M956 P0 S1000 A0 G4 P10 G1 X50 F20000.
      Can someone explain if this result has some sense and how to interpret it?
      0_2022-02-24_10.46.14.csv
        dc42 administrators @claustro last edited by dc42
        @claustro you can typically get a clearer result if you start the data collection immediately after the move has finished, like this:
        G1 X-50 G4 S2 G4 P10 G1 X50 F20000 M400 M956 P0 S1000 A0
        It's also worth doing a data collection with no movement, so that you can see any vibration from the fans.
        claustro 1 Reply Last reply Reply Quote 0
        • claustro
          claustro @dc42 last edited by claustro
          @dc42 Thank you very much for your answer and all the help you are giving to us.
          I collected the samples as you suggested. Here the results.
          do these results make any sense?
          I am reading the documentation about input shaping but I can't understand which input sharper method apply. ( ZVD, ZVDD , ZVDDD ecc...)
          Will something like this work or the frequency is too high?
          M593 P"zvd" F139
          • claustro
            claustro @claustro last edited by
            @claustro Any help?
            • claustro
              @claustro up
                Have you used 3.4 and the input shaping plugin?
