    question about use M581
    • Kevinundefined
      Kevin
      I have a question if it is possible.
      I came across a link on how to use M581.
      am currently using a duet 2 with rrf2 with an emergency stop on trigger9.g
      it is possible to add more buttons to trigger.g folders i read
      but is it right what i think ?
      exemple :
      button 1 extrude 100mm = trigger1.g G1 E100 F300
      button 2 retract 100mm = trigger2.g G1 E-100 F300
      button 3 G32 = trigger3.g Bed.g
      emergency stop = trigger4.g M24
      and what I read normal push buttons can be used,
      pressing once is then going through trigger.g command
      I hope it's easy to understand with google transstate 🙂
      • fcwiltundefined
        fcwilt @Kevin
        @kevin
        If you want a true emergency stop you need to specify trigger 0 in the M581 command.
        Triggers 0 and 1 are acted upon immediately.
        Triggers 2 and up don't execute until the current move is finished.
        If you want trigger 3 to execute bed.g just put G32 into the trigger3.g file.
        Kevinundefined 1 Reply Last reply Reply Quote 0
        • Kevinundefined
          Kevin @fcwilt
          @fcwilt
          the emergency stop runs on M24 pause during printing.
          ; Input/Output
          M581 E2 S1 T1 C1 ; Pause - trigger1.g
          M581 E3 S1 T2 C0 ; extrude 100mm - trigger2.g
          M581 E4 S1 T3 C0 ; retract 100mm- trigger3.g
          M581 E5 S1 T4 C0 ; G32- trigger4.g
          ; trigger1.g
          M24
          ; trigger2.g
          G1 E100 F300
          ; trigger3.g
          G1 E-100 F300
          ; trigger4.g
          G32
          so it is explained a bit more clearly what I was planning
          • fcwiltundefined
            fcwilt @Kevin
            @kevin said in question about use M581:
            @fcwilt
            ; Input/Output
            ; trigger1.g
            M24
            ; trigger2.g
            G1 E100 F300
            ; trigger3.g
            G1 E-100 F300
            ; trigger4.g
            G32
            When using trigger 0 (emergency stop - as if M122 was received) or trigger 1 (pause - as if M25 was received) there is no actual file used - it is handled directly by the firmware.
            Only triggers 2 and higher run a file.
            • Kevinundefined
              Kevin @fcwilt
              @fcwilt
              thanks for the quick response ,I know enough for now
              • dc42undefined dc42 marked this topic as a question
