    Duet 3 6hc clone issues
    • Budspencerundefined
      Budspencer
      Hi guys, new to the forum, in general I try to debugg myself alone using net ressources but I'm close to nervous breakdown with this board.
      Issue is that I can't get this thing to communicate by any mean.
      So far I've tried, USB and yat terminal, after installing duet drivers, it appears as Bossa port in devmgr, connects via Yat, but commands have no effect.
      Formatted SD, pushed a fresh config and tried to connect via DWC, nothing.
      Panel Due is also connecting forever.
      Any ideas of where to look for before buying an original Duet board, or someting else?
      Tanks for your help.
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Budspencer
        @budspencer Bossa port means that is waiting for a firmware to be installed on the board.
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
        Budspencerundefined 1 Reply Last reply Reply Quote 0
          Budspencer @Stephen6309
          @stephen6309
          Ok this confirms the obvious fact that all my tentatives can't be successful until I can have firmware flashed. But how can I do this I have no way to discuss with the board?? it looks like the chicken and egg problem..
          • oliofundefined
            oliof @Budspencer
            @budspencer if it appears as bossa port in devmgr, you should be able to flash it with the bossa flashing tool. See Fallback procedure #2 for details. If that doesn't work, you'll need to discuss the board being faulty with the seller.
              Budspencer
              @budspencer I did this yesterday and didn't work, this it went perfect, thanks mate!
