New firmware 1.20beta1
    I've added an item to that wiki page about a possible correlation with the temperature of the Duet.
  • Well, I have 2 big 40mm fans blowing on the Duet/Duex, triggered when CPU rises above 45°C, as you do…
    OK so temperature shouldn't be an issue, assuming you have calibrated the CPU temperature reading.
  • No, I didn't calibrate it! I have to do this…
    If your uncalibrated CPU temperature under-reads a lot, then the Duet could still be getting quite warm.
  • Well, in fact, default reading was 13°C above real CPU temp. So, fans started running at 35°C instead of 45°C. So CPU temp is not the issue.
  • Hi David,
    Is using the HW floating point beneficial to specific performance aspects at this point? Also, is this release including all of alpha 7 enhancements?
  • Feedback:
    In Chrome on Win10 x64 I can scroll down on pages (print status, gcode files, etc) but within a second or two (AJAX refresh?) it pops back to the top. 1.19 was the same where earlier versions did not.
    On a print I had going this morning, I was at 97% and slid the speed control from 100% to 112% and the board crashed/restarted. The print is still usable, just not done, but it was a functional part and the top doesn't matter really. At some point during that print, it had acquired a different IP address also which was interesting.
    @dcaron:
    Hi David,
    It mostly benefits particular machine architectures like SCARA which need to do a lot of floating point computations.
    @SuperJETT:
    Feedback:
    …On a print I had going this morning, I was at 97% and slid the speed control from 100% to 112% and the board crashed/restarted. The print is still usable, just not done, but it was a functional part and the top doesn't matter really. At some point during that print, it had acquired a different IP address also which was interesting.
    Did you run M112 after the restart to capture the software reset data? If so, please share it.
  • I actually did try m112 but it reset again. I'll do some testing to learn how to use that properly?
  • Great to have the new version out.
    In case of a heater error, will it pause the printer?
    @PropellerHat:
    Beta 1 doesn't, but beta 2 will.
  • @SuperJETT:
    Feedback:
    Same thing happens to me (Also In Chrome on Win10 x64) I'm still on 1.19, I was hoping 1.2 might fix it (but I guess not?)
    That would almost certainly be an issue between Chrome and DWC, so a firmware change won't help. I mostly use FireFox to access my Duets these days, because Chrome on my Win64 PC had a frequent habit of become completely unresponsive (on all tabs) for about 30 seconds before recovering - even when I wasn't connected to a Duet.
Locked
