    DWC Duet Web Control 3.4.0-rc2 no extrude or retract
    Duet Web Control
    707
    • moth4017
      moth4017 last edited by
      when the extruder is up to temperature the extrude and retract are grayed out, only available once gcode has been sent
      OwenD 1 Reply Last reply Reply Quote 0
      • OwenD
        OwenD @moth4017 last edited by
        @moth4017
        Is it on an SBC or stand alone?
        I don't see that on a Duet 2 stand alone.
        I can watch teh retract button become active as the temp passes the cold retract value and then the extrude button become active as I pass the cold extrude value.
        what do you get when you send
        echo heat.coldExtrudeTemperature
        and
        echo heat.coldRetractTemperature
        moth4017 1 Reply Last reply Reply Quote 0
        • moth4017
          moth4017 @OwenD last edited by
          @owend standalone duet3 + 5 mini
          0.0
          AM echo heat.coldRetractTemperature
          • OwenD
            @moth4017
            Strange the value is zero.
            Try sending something like
            M302 S210 R135
            Then try reheating
            https://duet3d.dozuki.com/Wiki/M302
            • moth4017
              @owend said in DWC Duet Web Control 3.4.0-rc2 no extrude or retract:
              M302 S210 R135
              should there be an M302 in the config file?
              • moth4017
                moth4017 @moth4017 last edited by moth4017
                @OwenD i do have a macro already with this in
                M302 ; status
                M302 P1 ; Allow Cold Extrude
                but that doesn't work either
                • OwenD
                  @moth4017
                  Normally you'd put an M302 in config.g or in your /filaments/"filament type"/config.g
                  I'm not sure what the defaults are if you don't.
                  M302 P1 should immediately activate the extrude/retract buttons (it does for me)
                  Please post your entire config.g and ensure that you have DWC version 3.4.0-rc2
                  Might be a job for @chrishamm
                    Post your config. Last time I saw this the tool didn't have an extruder motor assigned.
                    • moth4017
                      moth4017 @Phaedrux last edited by
                      @phaedrux
                      M550 P"Valkyrie 3030 V001" ; set printer name
                      M669 K1 ; core xy
                      G29 S1 ; Set Units to Millimeters
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P0.0 S1 ; physical drive 0 goes forwardsM569 P0.1 S1
                      M569 P0.1 S1 ; physical drive 1 goes forwardsM569 P0.1 S1
                      M569 P0.2 S1 ; physical drive 2 goes forwards
                      M569 P0.3 S1 ; physical drive 3 goes forwards (spare)
                      M569 P0.4 S1 D3 V30 ; physical drive 4 goes forwards D3=stealthchop
                      M569 P0.5 S0 D3 V30 ; physical drive 5 goes backwards
                      M569 P0.6 S1 D3 V30 ; physical drive 6 goes forwards
                      M584 X1 Y0 E2 Z0.4:0.5:0.6 ; set drive mapping FL,FR,RC
                      M350 X16 Y16 I1 ; configure microstepping with interpolation
                      M350 Z16 E16 I1
                      M92 X80.00 Y80.00 Z320.00 E260.00 ; set steps per m
                      M566 X500.00 Y500.00 Z800.00 E100.00 P1 ; set maximum instantaneous speed changes (mm/min)
                      M203 X8000.00 Y8000.00 Z1000.00 E400.00 ; set maximum speeds (mm/min)
                      M201 X1000.00 Y1000.00 Z200.00 E250.00 ; set accelerations (mm/s^2)
                      M906 X1000 Y1000 Z1000 E1400 I10 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S20 ; Set idle timeout
                      M208 X0 Y0 Z0 S1 ; set axis minima "Travel Area"
                      M208 X270 Y240 Z405 S0 ; set axis maxima "Travel area"
                      M574 X1 S1 P"!io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
                      M574 Y2 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
                      ;M574 Z2 S2 P"!io4.in" ; != invert signal
                      M574 Z2 S4 ; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors
                      M671 X-34.4:296:132.5 Y0:0:296 S25 ; leadscrews at front left,front right, rear Center s= max correction factor must be in same order as M584
                      ; Sensorless config
                      M915 P0.4:0.5:0.6 S5 R0 F0 H200 ; Lower values less sensitive S3, F filter, R =Action
                      M558 P8 C"!io3.in" H5 F600 T18000 A30 S0.03 ; set Z probe type to unmodulated and the dive height + speeds
                      G31 P500 Z0.5 ; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed
                      G31 P500 X26 Y6 ; set x,y trigger value, offset and trigger height
                      M557 X30:270 Y10:250 S40 ; define mesh grid
                      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed T°C" ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"out0" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 R0.140 K0.103:0.000 D43.19 E1.35 S0.90 B0 ; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950
                      M308 S1 P"temp1" Y"thermistor" T100000 B4267 A"Extruder T°C" ; configure sensor 1 as thermistor on pin e0temp (104gt2)
                      M950 H1 C"out1" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 R3.548 K0.733:0.000 D4.96 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit
                      M950 F0 C"out4" Q500 ; create fan 0 on pin fan0 and set its frequency
                      M950 F1 C"out3" Q500 ; create fan 1 on pin fan1 and set its frequency
                      M98 P/macros/3zhome
                      Stephen6309 Phaedrux 2 Replies Last reply Reply Quote 0
                      • Stephen6309
                        Stephen6309 @moth4017 last edited by
                        @moth4017 You don't have a T0 at the end to select Tool 0. Your M98 needs to be changed to M98 P"/macros/3zhome"
                          Phaedrux Moderator @moth4017 last edited by
                          @moth4017 said in DWC Duet Web Control 3.4.0-rc2 no extrude or retract:
                          G29 S1 does not set units to mm. It loads the heightmap, which shouldn't happen in config.g anyway. Best to remove that line.
                          moth4017 A Former User 2 Replies Last reply Reply Quote 0
                          • moth4017
                            @phaedrux removed G29, can you think of any reason why the extrude/retrack may not be working?
                              Is the tool selected? Your screen shot doesn't show the full window so it's hard to tell.
                              Can you share the results of M122 and M98 P"config.g"
                              It seems you're using a mini5+? But you have 6 drivers configured...
                              • moth4017
                                moth4017 @Phaedrux last edited by moth4017
                                M122
                                RepRapFirmware for Duet 3 Mini 5+ version 3.4.0rc1 (2022-02-09 10:27:22) running on Duet 3 Mini5plus WiFi (standalone mode)
                                Board ID: 3R9YY-6T9RL-D65J0-40KMN-2UW2Z-RHYT0
                                Used output buffers: 3 of 40 (14 max)
                                Static ram: 103652
                                Dynamic ram: 109368 of which 12 recycled
                                Never used RAM 28608, free system stack 154 words
                                Tasks: NETWORK(ready,12.6%,240) HEAT(notifyWait,0.0%,338) Move(notifyWait,0.0%,292) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,1.1%,114) MAIN(running,85.3%,428) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0%
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:04:03 ago, cause: power up
                                Last software reset at 2022-03-01 07:23, reason: User, GCodes spinning, available RAM 28608, slot 0
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                Error status: 0x00
                                MCU revision 3, ADC conversions started 243877, completed 243877, timed out 0, errs 0
                                Step timer max interval 955
                                MCU temperature: min 19.6, current 29.8, max 30.4
                                Supply voltage: min 23.7, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                Events: 0 queued, 0 completed
                                Driver 0: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22127, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                Driver 1: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22127, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                Driver 2: pos 96320, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22126, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                Driver 3: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22126, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                Driver 4: pos 0, standstill, SG min 152, read errors 0, write errors 0, ifcnt 16, reads 22120, writes 16, timeouts 0, DMA errors 0, CC errors 0
                                Driver 5: pos 0, standstill, SG min 16, read errors 0, write errors 0, ifcnt 16, reads 22119, writes 16, timeouts 0, DMA errors 0, CC errors 0
                                Driver 6: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 22118, writes 17, timeouts 0, DMA errors 0, CC errors 0
                                Date/time: 2022-03-02 16:52:41
                                Cache data hit count 459070420
                                Slowest loop: 118.95ms; fastest: 0.08ms
                                === Storage ===
                                Free file entries: 9
                                SD card longest read time 13.8ms, write time 11.5ms, max retries 0
                                DMs created 83, segments created 3, maxWait 624ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                === AuxDDARing ===
                                Heater 0 is on, I-accum = 0.2
                                Heater 1 is on, I-accum = 0.0
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is doing "M190 S85 " in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty
                                === CAN ===
                                Messages queued 2193, received 0, lost 0, boc 0
                                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 1220/0/0
                                Tx timeouts 0,0,1219,0,0,972 last cancelled message type 30 dest 127
                                === Network ===
                                Slowest loop: 52.60ms; fastest: 0.00ms
                                HTTP sessions: 1 of 8
                                • WiFi -
                                  Network state is active
                                  WiFi firmware version 1.25
                                  WiFi MAC address f0:08:d1:02:a1:0b
                                  WiFi Vcc 3.34, reset reason Power up
                                  WiFi flash size 2097152, free heap 26896
                                  WiFi IP address 192.168.0.19
                                  WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Clock register 00002002
                                M98
                                Error: M98: No P or R parameter
                                M669 K1 ; core xy
                                M350 Z16 E16 I1
                                ; Sensorless config
                                M98 P/macros/3zhome
                                  M98
                                  The command to send is M98 P"config.g"
                                  Can you please test with RC2?
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0rc2/DuetWebControl-SD.zip
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0rc2/Duet3Firmware_Mini5plus.uf2
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWiFiServer.bin
                                  • moth4017
                                    @phaedrux
                                    Hi had issues updating firmware via DWC
                                    Error: M997: In-application programming binary "0:/firmware/Duet3_SDiap32_Mini5plus.bin" not found
                                    so did the update via usb.
                                    M98 P"config.g"
                                    HTTP is enabled on port 80
                                    FTP is disabled
                                    TELNET is disabled
                                    Updated to rc2
                                    I worked out the issue i did not have any filaments loaded, didn't realise i had to enter a filament , im still not sure why it needs filaments in DWC as all the info comes from the slicer
                                      You appear to be missing this file.
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet3_SDiap32_Mini5plus.bin
                                      You should place it in the firmware directory to make future updates possible.
                                      I can't really make out the details in your screen shot. What do you mean by loading a filament?
                                      • moth4017
                                        @phaedrux
                                        once i had added a filament here see photo then the retract/extrude was available
                                        • moth4017
                                          @phaedrux
                                          since the new release of 3.4.0 i have this issue again where the retract and extrude is grayed out
                                          G90                                            	; send absolute coordinates...
                                          M83                                            	; ...but relative extruder moves
                                          M669 K1     									; core xy
                                          M569 P0.2 S1                                 	; physical drive 2 goes forwards ( blown needs replacing)
                                          M569 P0.3 S1                                	; physical drive 3 goes forwards (extruder
                                          M584 X1 Y0 E3 Z0.4:0.5:0.6               		; set drive mapping FL,FR,RC
                                          M350 Z16 E16 I1
                                          G31 P500 Z0.9									; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed
                                          M140 H0                                       					; map heated bed to heater 0
                                          M143 H0 S120                                   					; set temperature limit for heater 0 to 120C
                                          M307 H1 R3.435 K0.348:0.274 D6.64 E1.35 S1.00 B0 V23.9			; disable bang-bang mode for heater  and set PWM limit
                                          M563 P0 D0 H1 F0 T0                              ; define tool 0
                                          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                                          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                                          Stephen6309 1 Reply Last reply Reply Quote 0
                                          • Stephen6309
                                            @moth4017 Where do you select T0? I have a T0 at the bottom of config.g to make sure it's selected.
                                            • moth4017
                                              moth4017 @Stephen6309 last edited by
                                              @stephen6309 when i checked in the console which tool i have it has defaulted to T0 , but i have added it now to my config.g now.
                                              Thanks for the reply
                                              • moth4017
                                                @moth4017
                                                Ok even though the firmware new that the tool T0 was selected adding T0 to the config seems to have fixed this issue.
                                                • A Former User
                                                  A Former User @Phaedrux last edited by
                                                  This post is deleted!
                                                  • moth4017
                                                    @arnold_r_clark
                                                    Ill get some Rat poison 🙂
                                                    • martin7404
                                                      martin7404 last edited by
                                                      same here with 3.4
                                                      Found out that you have to select tool active , then it works
                                                      Muldex IDEX 3d printer Duet2+Duex5+Paneldue 7i
                                                      Custom CoreXY 600x400 Hemera , Duet3+toolboard v1.1, Paneldue 7i
                                                      Mod Sapphire Pro with Duet2 , with closed-loop motors
                                                      voron v0.1 and cr10s both running klipper; stock Bambu lab X1CC, X1C and P1P
