X and Y move opposite with same config
I have built a second machine using the same hardware and config file as the first machine and the X and Y axis move opposite than they did on the first. Swapped the drive directions easy enough but I'm curious why this would be.
Same model Duet board, same model LDO steppers, same config file, same firmware level on both boards. Using off the shelf stepper leads and wired new machine steppers same as old machine.
Other than possibly LDO changing the steppers between the two builds, any other thoughts on what could cause this?
Thanks in advance.
@aviationguy said in X and Y move opposite with same config:
That's the only thing I can thing of.
I've gotten a batch of Litton aircraft-grade steppers and has steppers FROM THE SAME BATCH wired differently.
I haven't thought about it deeply, but would a motor turn the other direction if they inserted the stator pack in the other-way-up in the casing? That's all I can think of.
