    active and stand by temps and switching tools
    • Tinchusundefined
      Tinchus
      Hello. Im using version 3.3 stable, duet 3 board connectd to a raspi.
      Im doing my dual tool configurations. Reading the wiki, the firmware when switching to a new tool at some point will set the stand by and active temperatures set on the last G10 command. If a parameter is not set, the previous last values of that parameter is still valid.
      But something is not working on this: my slicer superslicer is not putting a temperature setting on the tool switching, I have set so, so i was trusting the formware to do this. On my filament defnition, the last line on the load.g file I have set the command M568 P1 S230 R130 A0, so once the T1 tool is called, the temperature on T0 shoud be set to the standby temp of 130 degrees. That is not happening
      Can you help me on this? what could be wrong on my config?
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Tinchus
        @tinchus Do you have a G10 for Tool 0? Like: G10 P0 S239 R130
        I only have one tool, and I use G10 P0 S[first_layer_temperature] R140 in the start gcode for PrusaSlicer,
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @Stephen6309
          @stephen6309 No, my start gcode has a G10 P0 S230. Im trusting the R130 value is already being taken from the load.g file of the filament when I load it.
          • deckingmanundefined
            deckingman @Tinchus
            @tinchus The M568 in your load.g sets the active and standby temperatures for tool 1. You need to use M568 or G10 to set the active and standby temperatures for tool 0 as well.
            • Tinchusundefined
              Tinchus @deckingman
              @deckingman I did it. Even if I didnt, it is failing because the stand by temperature is not being set for T1 either
                deckingman @Tinchus
                @tinchus Please post your complete config.g file, config-overide.g if you use it, your start.g file, filament and tool change macros, and anything else which contains G10 or other temperature setting commands such as slicer start codes. The active and standby temperatures need to be set before you use any tool and this can happen in any of the aforementioned files which is why we need to see them. When a tool is activated, it will switch to the active temperature of the most recent G10 command, and when it is deactivated, it will switch to the standby temperature of the most recent G10 command.
                • Tinchusundefined
                  Tinchus @deckingman
                  @deckingman here you have the files. I have checked them, hopefully you see something I didnt:
                  tpre1.g tpre0.g tpost1.g tpost0.g tfree1.g tfree0.g
                  config.g config-override.g
                  I have no start.g file
                  M586 command with active and stand by temperatures are set on my load.g file of each filament. For T0 Im using for my tests tis is its file:
                  [ABS_PRO.zip](Invalid file type. Allowed types are:
                  load.g
                  And for T1 for the filament Im using to test (PVA), my load.g is:
                  load.g
                  Thanks in advance
