    Fusion Gcode
    • Budspencer
      Budspencer last edited by Budspencer
      Hi,I'm starting to test gcode out of Fusion, and I seem to have an issue with I and J arc factors.
      Saw on the duet wiki that those two are not supported.
      Is there any release after 3.3 that tackles this, or any known fix?
      For now I'm using the Workbee postproc, just looked at this one https://github.com/BruceRoyce/UltimateRepRapPost , but Fusion says it's invalid..
      Thks.
      alankilian 1 Reply Last reply Reply Quote 0
      • alankilian
        alankilian @Budspencer last edited by
        @budspencer
        Could you describe what you mean by:
        "I seem to have an issue with I and J arc factors. Saw on the duet wiki that those two are not supported."
        What GCODE are you having problems with and could you post a link to the Wiki that says what is not supported?
