    Babystepping --> Config: Sanity check
    • vwegert
      vwegert last edited by
      Hi all,
      I've found out I need to consistently set an offset of 0.05 mm through babystepping to avoid some first layer issues. In my config, I have
      G31 P100 X0 Y0 Z-0.1
      In order to make that change permanent, I would need to change the value to Z-0.05 - correct?
      (Side question - I'm using a smart effector, is this change likely to cause any issues?)
      Thanks
      Volker
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @vwegert last edited by
        @vwegert is that a positive babystep? If so, then you are correct about the change.
        It won't affect anything in terms of using the smart effector
