    What criteria to print layer the Slicer
    • peirofundefined
      peirof
      This is a curiosity that has arisen for me... Anyone know the criteria that the slicer uses to decide how many layers of to print?
      CASE A. EASY
      • You have to print an object 2 mm high, and you have selected in the slicer layers 0.2 mm. Not counting rafts, the printer will make 10 layers
      CASE B.
      • You have to print an object 2 mm high, and you have selected in the slicer layers 0.18 mm. Not counting rafts, the printer, how many layers will it make? 11 or 12?
      CASE C
      • You have to print an object 2 mm high, and you have selected in the slicer layers 0.23 mm. Not counting rafts, the printer, how many layers will it make? 8 or 9?
      Does this criterion depend on the slicer?
      engikeneerundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @peirof
        @peirof I believe most slicers just chose the number of layers that gives the closest height, so in case B it will do 11 layers and you'll get a 1.98mm high object
        i3 clone with a bunch of mods
        • fcwiltundefined
          fcwilt @peirof
          @peirof
          Is there a reason you would choose layer heights which don't yield exact results?
          peirofundefined 1 Reply Last reply Reply Quote 0
          • peirofundefined
            peirof @fcwilt
            @fcwilt It's simple curiosity.... Know what is the criterion used by Slicers, in case this is ever important for the piece that has a certain height ... But I don't know if I'll ever use it, if I print usually with layers of 0.16 /0.20, it's the maximum deviation I'm going to have. Curiosity
            achrnundefined 1 Reply Last reply Reply Quote 1
            • achrnundefined
              achrn @peirof
              @peirof It's not very difficult to test on whatever slicer you favour.
              On my PrusaSlicer the answer to case B is 11 layers, 1.98 high. It even shows you that in the user interface (no need to read gcode):
              Reading through the gcode, this is the last Z change (note that the gode has zero-based counting, so layer 10 is the 11th layer):
              G1 X-49.24 Y-49.159 E.02829
              ;LAYER_CHANGE
              ;Z:1.98
              ;HEIGHT:0.18
              ; layer change to layer 10 = 1.98mm
              G1 Z1.98 F10800
              G10 ; retract
              G1 X-49.383 Y-50.135
              G1 X49.383 Y-50.135
              Case C is 9 layers, 2.07 high:
              and
              G1 X-49.254 Y-49.194 E.03431
              ;LAYER_CHANGE
              ;Z:2.07
              ;HEIGHT:0.23
              ; layer change to layer 8 = 2.07mm
              G1 Z2.07 F10800
              G10 ; retract
              G1 X-49.399 Y-50.151
              G1 X49.399 Y-50.151
