    Solved Problem with Print Area
    • ertence
      ertence last edited by
      Hello everyone. I was working on my custom printer was about to get a test print
      but the problem is it prints somewhere outside the print area I chose the black area which is selected as print area the red area is the machine starts to print
      the Z-axis probing is functional there is no problem with probing its working well. WhatsApp Image 2022-03-05 at 14.13.38.jpg
      Here is my config file
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Tue Jan 26 2021 16:38:54 GMT+0100 (Central European Standard Time)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"nøkk3d"                  ; set printer name
      M564 H0
      ;M551 P"ERTENCE"                           ; set password
      M552 P192.168.1.21 S1                       ; enable network and set IP address
      M553 P255.255.255.0                          ; set netmask
      M554 P192.168.0.1                            ; set gateway
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0 S1                                 ; physical drive 0.0 goes forwards
      M569 P1 S1                                 ; physical drive 0.1 goes forwards
      M569 P2 S1                                 ; physical drive 0.2 goes forwards
      M569 P3 S0                                 ; physical drive 0.3 goes forwards
      M569 P4 S0                                 ; physical drive 0.3 goes forwards
      M569 P5 S0                                 ; physical drive 0.3 goes forwards
      M584 X5 Y1:2 Z3 E4                           ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E436.54            ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E500.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z400.00 E500.00    ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z25.00 E400.00          ; set accelerations (mm/s^2)
      M906 X1400 Y2500 Z2500 E1700 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M208 X-25 Y-35 Z0 S1                         ; set axis minima
      M208 X10000 Y490 Z500 S0                     ; set axis maxima
      M574 X1 S1 P"io4.in"                         ; configure active-high endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io0.in"                         ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"io3.in"                         ; configure active-high endstop for low end on Z via pin io2.in
      M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-30 Y-2 Z3.5                       ; set Z probe trigger value, offset and trigger height
      M557 X20:980 Y10:490 S120                     ; define mesh grid
      M308 S0 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out2" T0 Q1                       ; create heater output on out0 and map it to sensor 0                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H0 S70                                 ; set temperature limit for heater 0 to 70C
      M140 P1 H0
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 Q1                       ; create heater output on out1 and map it to sensor 1                           ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H1 S70                                 ; set temperature limit for heater 1 to 70C
      M140 P2 H1
      M308 S2 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H2 C"out3" T2 Q500                       ; create heater output on out1 and map it to sensor 1                           ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H2 S350                                 ; set temperature limit for heater 1 to 70C
      M307 H0 A200.8 C850.6 D2.0 S1.00 V24.0 B0
      M307 H1 A200.0 C850.0 D2.0 S1.00 V24.0 B0
      M307 H2 A491.0 C185.5.0 D4.9 S1.00 V24.0 B0
      M950 F0 C"out8" Q3000                         ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q3000                         ; create fan 1 on pin out5 and set its frequency                            ; set fan 1 value. Thermostatic control is turned on
      M106 P1 T45 S1.0 H2
      M563 P0 D0 H2 F0                             ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      Best regards
      Rushmere3D 1 Reply Last reply Reply Quote 0
      • achrn
        achrn last edited by
        I don't know Cura but it looks like you've told it to generate the print gcode with X values between -25 and 25, and in your config.g you've told the printer that -25 is the position where the X endstop triggers:
        So it's going to print in the region between where the endstop triggers and 50mm offset from that.
        For a cartesian, personally I set origin to front left printable position so if the point where endstops trigger is the extreme printing position your M208 should be M208 S1 X0 Y0 Z0.
        Then in Cura if you want to limit usable bed to be just the printable region you'd set X min to 475 and X max to 525.
        • Rushmere3D
          Rushmere3D @ertence last edited by
          @ertence
          Might have something to do with the fact Cura seems to be set to have Zero in the middle of the bed, but you're config.g isn't from what I can see?
          Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
            In your Cura settings, uncheck Origin at center.
            ertence 1 Reply Last reply Reply Quote 0
            • ertence
              ertence @Phaedrux last edited by
              @phaedrux It worked, thanks a lot
              • Topic has been marked as a question  droftarts droftarts
              • Topic has been marked as solved  droftarts droftarts
