    Unsolved Paneldue v. 1.0 & RRF 3.4 with no heated bed possible?
    PanelDue
    • fotomas
      fotomas last edited by
      I have just upgraded an DuetWiFi controlled Cetus3D printer from RRF 2.x to 3.4.0-rc2.
      It has a panel due version 1.0 (separate control board connected with a 40 pin ribbon cable) connected that I have flashed with firmware 1.25.
      My problem is that the Cetus3D do not have a heated bed and on the paneldue there are only values below the bed column, not the hotend column.
      It this even possible with my setup? If so how?
      config.g below
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Mar 08 2022 19:58:56 GMT+0100 (Central European Standard Time)
      M575 P1 S1 B57600                             ; enable support for PanelDue
      G90                                           ; send absolute coordinates...
      M83                                           ; ...but relative extruder moves
      M550 P"NAME"                                 ; set printer name
      M552 S1                                       ; enable network
      M586 P0 S1                                    ; enable HTTP
      M586 P1 S0                                    ; disable FTP
      M586 P2 S0                                    ; disable Telnet
      M569 P0 S0                                    ; physical drive 0 goes forwards
      M569 P1 S1                                    ; physical drive 1 goes forwards
      M569 P2 S1                                    ; physical drive 2 goes forwards
      M569 P3 S1                                    ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                              ; set drive mapping
      M92 Y88.68 X88.68 Z79.72 E932.00       	  	  ; Set steps per mm; used to be E127, 118 for CETUS; Hemera E409; HIQU H2 932
      M566 X600.00 Y600.00 Z150.00 E800.00          ; Set maximum instantaneous speed changes (mm/min)
      M203 X28000.00 Y28000.00 Z15000.00 E10000.00  ; Set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z100.00 E1500.00       ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z600 E500 I50                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S10                                       ; Set idle timeout
      M350 X256 Y256 Z256 I0                        ; configure microstepping without interpolation
      ;M350 E16 I1                                   ; configure microstepping with interpolation
      M208 X0 Y0 Z0 S1                              ; set axis minima
      M208 X180 Y180 Z183 S0                        ; set axis maxima
      M574 X1 S3                                    ; configure sensorless endstop for low end on X
      M574 Y1 S3                                    ; configure sensorless endstop for low end on Y
      M574 Z1 S2                                    ; configure Z-probe endstop for low end on Z
      M915 X Y R0 F0 S4 							  ;sensroless homing
      M558 P1 C"zprobe.in" H6 F400 T6000            ; set Z probe type to unmodulated and the dive height + speeds
      G31 P515 X-31 Y0 Z1.35                        ; set Z probe trigger value, offset and trigger height
      M557 X5:180 Y5:180 S30                        ; define mesh grid
      G29 S1 										  ; Load stored mesh grid from SD Card
      M140 H-1                                  ; disable heated bed (overrides default heater mapping)
      M308 S0 P"e0temp" Y"thermistor"               ; configure sensor 0 as Thermistor on pin e0temp
      M950 H0 C"e0heat" T0                      ; create nozzle heater output on e0heat and map it to sensor 0
      M307 H0 R1.787 K0.292:0.000 D6.79 E1.35 S1.00 B0 V19.4
      M143 H0 S280                              ; set temperature limit for heater 0 to 280C
      ; Sensors
      M308 S10 Y"mcu-temp" A"MCU"
      M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 H10 T34                              ; set fan 0 value. Thermostatic control is turned on, using sensor 10
      M950 F1 C"fan2" Q500                          ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H0 T50                               ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan1" Q500                          ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1 F12 L110 X190 C"Part Cooling"                             ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Hotend" D0 H0 F2                ; define tool 0
      G10 P0 X0 Y0 Z0                           ; set tool 0 axis offsets
      G10 P0 R0 S0                              ; set initial tool 0 active and standby temperatures to 0C
      T0                                        ; select first tool
      oliof 1 Reply Last reply Reply Quote 0
      • oliof
        oliof @fotomas last edited by
        @fotomas The definition of thermistors and heaters changed between RRF 2.x and RRF 3.x -- I would suggest you recreate a basic config using the reprap configurator
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        fotomas 1 Reply Last reply Reply Quote 0
        • fotomas
          fotomas @oliof last edited by
          @oliof that is exactly what i did, see comment at the top of config.g
            I think this may be a hard limit of the older V1 boards. Since it is a PanelDue with a separate board, you may be able to buy a V3 board to swap with, which would allow the use of the 3.x Paneldue firmware.
            Or perhaps you could create a dummy heater for the bed to take up the position.
