How to upgrade to 3.4RC2?
I have Duet mini 5 with 3.4.0beta5 (2021-10-12) and paneldue I5 with firmware version 1.24. How do I upgrade to the latest 3.4.0rc2? (what files to download?, how to apply them?, do I need to modify my config.g and macros to adapt to changes?, etc)
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0rc2
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0rc2/Duet3Firmware_Mini5plus.uf2
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0rc2/DuetWebControl-SD.zipJust the mini5 plus firmware file and the DWC files. You can either upload it via DWC or use the mini5 plus firmware update over USB.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#duet-3-mini-5-wifiethernet
3.4 final should be out very soon, so maybe easier to just wait for that and upload as normal by uploading the full zip file package.
For the PanelDue you'll need to update via BOSSA, but once you're using a 3.3 firmware on the 5i you should be able to update via DWC as well.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
Thanks @phaedrux. I will give it a try. I hope it will fix the PWM issue I mentioned in another thread.
3.4 just released today as well.
Thanks @phaedrux. installed.
