DUEX 5 V0.8 TO DUEX 5 V0.11
@droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
@paolozampini1973 Sorry, I don't know if NEMA 23 will run better than NEMA17 with your external drivers on your machine. You will just have to test them.
M569 P7 S0 R1 T5:5:10:10 ; E4 X physical drive 7 goes forwards
M569 P8 S1 R1 T5:5:10:10 ; E5 Y physical drive 8 goes forwards
M569 P9 S1 R-1 ; E6 Z physical drive 9 goes forwards
M584 X7 Y8 Z1:2 E3:4:5:6 S0 ; set drive mapping
M671 X0:0 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping without interpolation
M92 X99.975 Y99.975 Z800.10 E392.70:392.70:392.70:392.70 ; set steps per mm
M566 X1000.00 Y1100.00 Z1500.00 E5000.00:5000.00:5000.00:5000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X10000.00 Y10000.00 Z4500.00 E10000.00:10000.00:10000.00:10000.00 ; set maximum speeds (mm/min)
M201 X2400.00 Y2400.00 Z1500.00 E4000.00:4000.00:4000.00:4000.00 ; set accelerations (mm/s^2)
M906 X0 Y2000 Z2000 E1500:1500:1000:1000 I90 ; set motor currents (mA) and motor idle factor in per cent
M84 S15 ; Set idle timeout
Yes so it doesn't lose the pace I'm trying now
100 mm of printing and 130 of displacement -
someone can explain to me why I start printing a rectangle 200 mm x 20 mm and when it starts printing it starts printing 55 mm after this means that on a line of 200 mm It only prints 145 mm because?
config (30).g -
@paolozampini1973 as this is a new issue, use your new thread. I have undeleted it.
