    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
    • paolozampini1973undefined
      paolozampini1973 @paolozampini1973
      @droftarts A TIP I WANT TO CHANGE NEMA 17 17HS19-2004S1 TO NEMA 23 23HS22-2804S BECAUSE WITH THE WEIGHT TO MOVE, HAVING DOUBLE TORQUE, I COULD INCREASE PERFORMANCE
      17HS19-2004S1.pdf
      23HS22-2804S.pdf
      paolozampini1973undefined 1 Reply Last reply Reply Quote 0
        @droftarts
        I have a problem with the Z axis manual override works fine driver 0 direction + and - driver 2 direction + and -
        but when I give the command home all or home z it works only driver 0 direction + driver 2 direction + and - and drive 0 not returning in direction z- that towards z- there are the two switches of driver 0 and driver 2 which are used for self-leveling problem I don't understand that it has always worked until yesterday and today it doesn't work. I have not made any changesconfig (26).g homez.g homeall.g
        I forgot to say that if I follow the command return home X the Z axis moves direction + driver 0 and driver 2 waits for x to return home and then moves driver 0 and driver 2 - and normal operation occurs the same way too y regularly performs the same function
          @droftarts Hello I haven't been able to do the print tests yet because I have the problem with Z
          please can you help me i can't understand the problem i have Z It's since yesterday i can't find the problem
            droftarts administrators @paolozampini1973
            @paolozampini1973 I have been testing this, and I think one of your endstops is not working. Either broken wiring, connected in the wrong place, or incorrect configuration.
            When you send M119 with no endstop triggered, it should report "Z: not stopped". When you press either, or both, of the endstops, it should report "Z: at min stop". If one of the endstops does not report a change, check the wiring.
            I have also tested endstop inputs on a DueX5 v0.11 in DueX2 mode, and all endstop inputs on the DueX worked correctly.
            This is your current configuration:
            M574 X0 S1 P"!xstop"                                ; configure active-high endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop"                                ; configure active-high endstop for low end on Y via pin ystop
            M574 Z2 S1 P"!zstop+!E1stop"
            'X0' means 'no endstop'. If it is at the low end (ie when triggered, X is at 0), change to X1.
            'Z2' means 'at the high end', ie when Z is at 320. But I think your machine homes Z when the nozzle is close to the bed, which is the 'low end'. Change to Z1.
            See https://docs.duet3d.com/User_manual/Reference/Gcodes/M574
            paolozampini1973undefined 3 Replies Last reply Reply Quote 0
              paolozampini1973 @droftarts
              @droftarts No I think I have not explained myself iswitch have absolutely nothing to do with it I try to explain myself anyway Thanks thanks you made me feel it is not a hardware problem I will also explain to you why Z moves towards the more regularly when I go home with y and then comes back towards the less than 15 mm and this is regular if I do it with X it goes 15 mm towards the plus and then returns towards the less than 15 mm and this is also regular but if I do it with Z it goes home they rise towards the plus 15 mm and then only one axis returns 15 mm the basket what comes home with everything Iasi but it has absolutely nothing to do switch no Switch it is a configuration problem that I am seeing somewhere it is wrong with this I'm sure to 1000 * 1000 I hope I have been able to explain to me why the switch is not getting there but I have a configuration problem Suicide tested and work well Everyone changes Status no problem with Switches
                @droftarts I can make a very short video but I don't know if I can publish it here
                I have probably changed a parameter that I cannot understand which parameter I have changed the problem I have it only with Z it comes home and with it returns home all the axes coach X returns home I have no problems Z gets up and yes lowers both axes at the same time and is correct with Y the same thing goes up by 15 mm and low series regularly with both axes of Z and works regularly I hope I explained Thanks
                SIamundefined 1 Reply Last reply Reply Quote 0
                • SIamundefined
                  SIam @paolozampini1973
                  @paolozampini1973 I would say post a video, sometimes it is an easier way to solve problems
                  Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                  Duet WiFi 1.02 or later + DueX5
                  RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                  Duet WiFi Server: 1.26
                  Duet Web Control 3.4.0beta4 (2021-09-27)
                    @droftarts i reversed the problem before it was configured like this M584 X0 Y1 Z2: 1 E3: 4: 5: 6 Now I configured it this other way M584 X0 Y1 Z1: 2 E3: 4: 5: 6 the result that before I had the problem on the left Now I have what you say on the right now I understand But why why has it always worked like this for months and now I have the problem I do not understand and above all it has also worked so the day before yesterday after we made all the changes
                    M574 Z1 S1 P"!zstop+e1stop"
                    please help me because it doesn't make sense. It always worked because now it doesn't work anymore. The thing is too weird
                    SIamundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    • SIamundefined
                      @paolozampini1973 Did you use two different motors for the z axis ?
                      M569 P1 S0 R1                                      ; Y    physical drive 1 goes forwards
                      M569 P2 S1                                         ; Z    physical drive 2 goes forwards
                      If you use the same motors with the same wiring, I would say you need to configure both motors the same way
                        paolozampini1973 @SIam
                        @siam Listen Thanks for the intervention but the machine has been running like this for months
                        How do I cut a video ? you tell me the size is too big
                          @paolozampini1973 The order you define the axes in M584 and endstops in M574, configures the endstop for the axis. We moved them around the other day, so it's possible they got swapped.
                          With
                          M584 X0 Y1 Z2:1 E3:4:5:6
                          Z2 uses zstop, Z1 uses e1stop.
                          The same is true of leadscrew position, M671; the first leadscrew is the first one defined in M584.
                            @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                            Use youtube, post link. Can't upload videos to Duet3D forum.
                              @droftarts
                              M574 Z2 S1 P"!zstop" ?
                              M574 Z1 S1 P"e1stop" ?
                              but Forgive me Excuse me for what reason it always worked even after when we made the changes I did the print tests it worked after we also made the changes and now it doesn't work anymore it's a very strange thing You can help me understand Thanks
                                @droftarts
                                NO. Z parameter in M574 sets where the endstop is physically, on the axis. High or low. Both endstops are low, and combined together. Listing them separately is incorrect. You also seem to have lost the inversion on the e1stop. It should be:
                                M574 Z1 S1 P"!zstop+!e1stop"
                                paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                                  @droftarts
                                  M574 Z1 S1 P"!e1stop"
                                  So this is how it works that it goes towards the plus and then returns towards the minus but the first switch intervenes you can see both AXES
                                    @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                                    @droftarts
                                    NO. Z parameter in M574 sets where the endstop is physically, on the axis. High or low. They both should be Z1. Listing them separately is incorrect, too. You also seem to have lost the inversion on the e1stop. It should be:
                                    so it doesn't do the inversion it goes towards the plus and it doesn't come back towards the minus but the thing I don't understand why it doesn't work anymore has always worked even after we put our hands on it
                                      @paolozampini1973 What does M119 report when:
                                      No switch is pressed
                                      Z1 endstop is pressed
                                      Z2 endstop is pressed
                                      Both endstops are pressed
                                      And post the endstop configuration you are using when testing.
                                        @droftarts So the problem is not the speech of switches that have to close and open because practically when you give it back home it goes up 15 mm and then it has to do the inversion towards minus putting the separated the inversion towards minus does it however I repeat not get to the switches I have now done a try to take it myself manually the switches work both tested they work it is not a problem of the switches it is a problem towards the plus and then return towards the minus towards the Switch clearly if only one axis works only l the axis is rightly placed sideways
                                          @paolozampini1973 Please just do the test and report, using M574 Z1 S1 P"!zstop+!e1stop" for configuration. It won't work with two separate M574 commands.
                                            25/3/2022, 17:34:11 M574 Z2 S1 P"!zstop!+!e1stop"
                                            Error: M574: Unknown pin name 'zstop!'
