    configuring Co2 laser enable pin
    Laser Cutters
    • rabbit
      rabbit last edited by
      I'm wondering how to configure the enable pin of a co2 laser. It would be great, if I could trigger an output with the M3 gcode or is it already possible?
      Can somebody who uses a duet with a co2 laser share his configuration for the laser?
      best,
      Vincent
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @rabbit last edited by
        @rabbit my co2 laser (k40) is just wired to the negative of the bed heater output. It's then set using M452.
        I can then use M3 to enable and M5 to disable
        apak 1 Reply Last reply Reply Quote 0
        • apak
          apak @jay_s_uk last edited by apak
          @jay_s_uk I just got my K40 out of the box, and would like to rewired everything to a new duet3 mini 5, have you documented your machine, where can I find some info?
          • jay_s_uk
            jay_s_uk @apak last edited by
            @apak this should help you. its with an SKR2 rather than a duet 3 mini but the principals are the same
            https://github.com/TeamGloomy/LPC-STM32-RRFUserConfigs/tree/master/K40 CO2 Laser - SKR 2 - ESP - paulg4h
            • apak
              @jay_s_uk will take a look, thx
