    Filements in RepRapFirmware, fw or doc issue?
    207
    • Megamannen
      Megamannen last edited by
      https://docs.duet3d.com/User_manual/Reference/Gcodes#m701-load-filament
      Why is this command running the configure.g-script?
      Is this a bug in firmware or a bug in documentation?
      When called the firmware does the following:
      Run the macro file "load.g" in the subdirectory of the given material (e.g. /filaments/PLA/load.g)
      Change the filament name of the associated tool, so it can be reported back to Duet Web Control
      I was planning on having M701 PLA more as an state.
      And in my start g-code have a M703 to activate heaters
      gloomyandy Phaedrux 2 Replies Last reply Reply Quote 0
      • gloomyandy
        gloomyandy @Megamannen last edited by
        @megamannen See https://docs.duet3d.com/en/User_manual/Reference/DWC_filaments for a more complete discussion of the filament handling process.
        Megamannen 1 Reply Last reply Reply Quote 0
        • Megamannen
          Megamannen @gloomyandy last edited by
          @gloomyandy yeah, and that also states that you should do a 703 to load specific config for the loaded filament.
          Now that is done automatically. Which doesn't match the documented behaviour
            Phaedrux Moderator @Megamannen last edited by Phaedrux
            @megamannen said in Filements in RepRapFirmware, fw or doc issue?:
            What exactly do you mean by this?
            What firmware version are you using?
            • Megamannen
              Megamannen @Phaedrux last edited by
              @Phaedrux
              According to documentation M701 runs "filamanets/PLA/load.g" and you should run M703 to run "filamanets/PLA/config.g"
              But when I load PLA it runs both filamanets/PLA/load.g and filamanets/PLA/config.g
              (now I get unsure if it's the web-gui that does a M701 + M703 on filament change or if it's the M701 that does this undocumented behaviour)
              fcwilt OwenD 2 Replies Last reply Reply Quote 0
              • fcwilt
                fcwilt @Megamannen last edited by
                @megamannen
                If you load a filament from the DWC it first runs load.g for that filament and then runs config.g for that filament.
                • Tinchus
                  Tinchus last edited by
                  I have just found this post after posting my own. Im having the same issue on 3.4 stable.
                  Docementation says for loading a filament, load.g will be executed but for executing the config.g I have to call for it using M703. But that is not happening: after load.g, the config.fg file is executed automatically.
                  Is this a bug or a new behaviour not documented?
                    DWC runs both and always has. It's different than running M701 by itself.
                    • OwenD
                      OwenD @Megamannen last edited by
                      DWC issues all the commands necessary to complete the task at once.
                      My comments in this thread also apply here
