Is a 1ftx1ftx2ft build volume doable with a hotbed?
@virgosystems said in Is a 1ftx1ftx2ft build volume doable with a hotbed?:
@fcwilt well I was referring specifically to the smaller stuff - bolts etc
I get my hardware like that from Amazon. They have assortments of common metric sizes - 2.0 / 2.5 / 3.0 / 4.0 / 5.0 and 6.0 if you need something that robust.
RTL Fasteners has a good selection of items as well.
I use both socket head and button head styles.
@mrehorstdmd btw, what's that on the floor? Just motors?
@virgosystems Misumi has t-slot at reasonable rates and from what I hear, their cuts are square and accurate length. I buy t-slot at a couple local scrap yards for scrap aluminum price.
I buy quality linear guides via ebay- not Hi-Win knockoffs, but brands like IKO, Thomson, Bosch, etc. Hi-Win makes good guides, but their numbering scheme has been copied by dozens of factories in China that make poor quality parts, so unless you buy from a Hi-Win dealer, I'd stay away from anything with a MGN type part number.
This is the Z axis motor/gearbox I used: https://www.ebay.com/itm/191714031261?epid=711126295&hash=item2ca30bf69d:g:A7UAAOSwPhdVB2f0
For $108 you get the motor and the best quality gears you'll ever find for the cost of a motor plus brake (and a lot of screwing around to get the brake working). The advantage of the geared mechanism is that the bed absolutely will not move when power is lost, and you can move a very heavy bed assembly with it, and there's no special configuration required- just set steps per mm and microstepping and you're done. With the pulleys I am using I get 20 um per full step of the motor, so I use layer thicknesses that are multiples of 20 um. I have measured belt stretch with glass and steel core belts and it is inconsequential in both cases.I used 40x40 t-slot for the frame with some fore/aft corner bracing. The side panels are dual layer polycarbonate of the sort used for making greenhouses. It provides thermal insulation and lets light through, but does not help to stiffen the printer's frame. Sheets of almost any rigid material screwed to the sides of the enclosure would provide increased rigidity. The front doors are made of clear polycarbonate sheet, the lower one held on the frame with magnetic tape, the upper one slides up/down in the slots in the t-slot frame.
The t-slot I used has 8mm wide slots, so I was able to use cheap 5/16" carriage bolts to hold some of the parts together. I used t-nuts in some places, ordered via ali-express. I think I ordered some other hardware through amazon.com.
I never made a BOM, mostly because it's unlikely that others would be able to get the exact parts I used and it was enough trouble to build the machine without trying to document it in that much detail. You'll notice that my CAD files lack many of the nuts and bolts that hold the machine together.
In the bottom of the printer you're seeing the red gearbox/motor at the center, and just behind them is the SSR that switches power to the chamber heater. There's a single 8mm shaft through the gearbox that drives pulleys/belts on the right and left sides of the machine. There is also a piece of sheet steel mounted on the back of the motor to deflect the warm air blowing over the chamber heater.
More on the machine here.
There have been many updates to the original design which can be found in different posts- search the blog for "UMMD". -
1x1x2 volume
Have you considered starting with a Voron V2.4 and stretching it in the vertical direction? It uses belts for Z movement so should be easier than stretching rods, and because the the gantry moves in z direction, you will have a lower center of gravity and better stability.
@zapta a little pricier than I wanted but worth a look. Besudes, wouldn't modifications void the warranty?
@mrehorstdmd oh the cad files are a massive help. Thanks so much.
Vorons are built from self sourced parts and from kits. I there is any warranty, I don't think it will be affected.
You can try the Voron V2.4 configurator. Select custom and enter the Z value you want.
@mrehorstdmd how much spare time do you have? I have a business proposal you may find interesting.
This post is deleted! -
@mrehorstdmd sent
