    Solved Connecting the heaters
    134
    • CrazyCreator
      CrazyCreator last edited by CrazyCreator
      Is it a problem if I connect the heaters for the toolheads to out1 - out4 on the MB6HC3
      ; Heaters and temperature sensors
      ; Bed
      M308 S0 P"1.temp0" Y"thermistor" T100000 B4138 A"Heizbett"                      ; configure sensor 0 as thermistor on pin 1.temp0
      M950 H0 C"1.out0" T0                                                            ; create bed heater output on 1.out0 and map it to sensor 0
      M307 H0 B0 S1.00        ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0        ; map heated bed to heater 0
      M143 H0 S140 																	; set temperature limit for heater 0 to 140C
      ; Nozzle Heater Config
      ; Tool 0
      M308 S1 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8                           ; configure sensor 1 as thermistor on pin temp0
      M950 H1 C"out1" T1                                                              ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280        ; set temperature limit for heater 1 to 280C
      ; Tool 1
      M308 S2 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8                           ; configure sensor 2 as thermistor on pin temp1
      M950 H2 C"out2" T2                                                              ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280        ; set temperature limit for heater 2 to 280C
      ; Tool 2
      M308 S3 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8                           ; configure sensor 3 as thermistor on pin temp2
      M950 H3 C"out3" T3                                                              ; create nozzle heater output on out3 and map it to sensor 3
      M307 H3 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S280        ; set temperature limit for heater 3 to 280C
      ; Tool 3
      M308 S4 P"temp3" Y"thermistor" T100000 B4725 C7.06e-8                           ; configure sensor 4 as thermistor on pin temp3
      M950 H4 C"out4" T4                                                              ; create nozzle heater output on out4 and map it to sensor 4
      M307 H4 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H4 S280        ; set temperature limit for heater 4 to 280C
      ; System Temperature Sensors
      M308 S10 Y"mcu-temp" A"MCU"														; MCU Temp
      M308 S11 Y"drivers" A"Steppers"													; Stepper Driver Temp
      http://www.crazycreatorcube.com
      jumpedwithbothfeet 1 Reply Last reply Reply Quote 0
      • jumpedwithbothfeet
        jumpedwithbothfeet @CrazyCreator last edited by
        @crazycreator I don't believe out4 is designed to run heaters directly and are mainly aimed at fans etc, I think you would struggle with the current needed, if you need another heater it will be safer to use an expansion board like a tool board.
        Voron Trident based (4Z) - too much to list!
        • CrazyCreator
          Can i also use out0 as an output for the HotEnd-Heater, or is it only intended for the bed heater?
          jay_s_uk 1 Reply Last reply Reply Quote 0
          • jay_s_uk
            jay_s_uk @CrazyCreator last edited by
            @crazycreator you can use out0
            • CrazyCreator
              hi @jay_s_uk
              That's what I originally thought too...
              But nothing happens on out0 (these are the screwable connections, right?). The multimeter shows 0 volts.
              This is what the config looks like:
              ; Bed
              ; Tool 0
              M950 H1 C"out0" T1                                                              ; create nozzle heater output on out0 and map it to sensor 1
              ; Tool 1
              M950 H2 C"out1" T2                                                              ; create nozzle heater output on out1 and map it to sensor 2
              ; Tool 2
              M950 H3 C"out2" T3                                                              ; create nozzle heater output on out2 and map it to sensor 3
              ; Tool 3
              M950 H4 C"out3" T4                                                              ; create nozzle heater output on out3 and map it to sensor 4
                Out0 will only output VIN if you have connected VIN to the OUT_0_input terminals.
                See the wiring diagram for the Duet 3 and study the terminal block.
                • CrazyCreator
                  Ahhhh... thanks for the tip...
                  I can just do it like in my quick drawing:
                    Yes a short jumper is fine.
                    • CrazyCreator
                      then I'll try that
                      • CrazyCreator
                        as soon as you do it right, it works 😉
                        • Topic has been marked as a question  Phaedrux Phaedrux
                        • Topic has been marked as solved  Phaedrux Phaedrux
