    Resurrect print - Babystepping issues
    • Trideo
      Trideo last edited by
      Hello
      We’ve been having issues with our prints when the resurrect print feature is used, specifically in the cases were babystepping has been applied previously.
      We know the babystepping in itself is only meant as an auxiliary tool but in our case we have found there are two use scenarios were its use is necessary for us:
      -When printing with our heated chamber machines as the variations between materials and temperatures often require adjustments in the first layer
      -When printing with our one cubic meter machines as they are located in a warehouse and the bed behaviour varies depending on the climate.
      It’s been noticed that the machine reapplies the babbystepping at the resurrect.g before launching the print.
      As we do not home the Z axis when the resurrect is launched then the posible outcomes are the following:
      Assuming that when there is a power outage the Z will remain at the correct height then reapplying a negative stepping will lead to the nozzle going further into the model and reapplying a positive stepping will lead to the nozzle getting further away from the model.
      Is there any way to avoid this ?
      As the resurrect.g is launched after the resurrect_prologue then we haven´t been able to find a way to clear the babystepping prior to the resuming of the print
      Thanks in advance
      Trideo3D team.
      Phaedrux infiniteloop 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @Trideo last edited by
        @trideo said in Resurrect print - Babystepping issues:
        I wonder if you could add the clearing of babysteps to the M911 command.
        • infiniteloop
          infiniteloop @Trideo last edited by
          @trideo Maybe you want to add
          M290 R0 S0  ; clear babystepping
          to your config.g? As you use baby stepping only to adjust the first layer, that is, on a per-print basis, it does no harm to always start with no babysteps when you power-up the machine.
