    Slow warmup on the heated bed
    120
    • Heide
      Heide last edited by
      I have this issue.
      Can someone explane what goes on here?
      Voron CoreXY with Duet 3 + expansion + PanelDue 7i - 300 * 300 * 300 and Hemera Revo
      Th0mpy jay_s_uk 2 Replies Last reply Reply Quote 0
      • Th0mpy
        Th0mpy @Heide last edited by
        @heide What type of heated bed do you have?
        Usually the team that scores the most points wins the game.
        Heide 1 Reply Last reply Reply Quote 0
        • Heide
          Heide @Th0mpy last edited by
          @th0mpy Keenovo 450 W - 230 V
          Th0mpy 1 Reply Last reply Reply Quote 0
          • Th0mpy
            Th0mpy @Heide last edited by Th0mpy
            @heide Ok, that error simply means the bed is not heating (or Duet does not detect it as such). Does the bed feel warm? There are a number of things you can check, firstly if the bed is warm the thermistor may be disconnected or broken. Secondly is your relay working, and do you detect a completed circuit or full 220 volts when on?
            You may also want to check to see that your bed thermistor is configured properly. Are you using the keenvo thermistor that's embedded in the silicone pad? Can you post your config?
            • jay_s_uk
              jay_s_uk @Heide last edited by
              @heide tune your bed using M303 H0 S60
              Phaedrux 1 Reply Last reply Reply Quote 1
                Phaedrux Moderator @jay_s_uk last edited by
                @jay_s_uk said in Slow warmup on the heated bed:
                And make sure to send M500 to save the results to config-override.g and add M501 to the end of config.g to load them at startup.
                Heide 1 Reply Last reply Reply Quote 1
                • Heide
                  Heide @Phaedrux last edited by
                  @phaedrux @jay_s_uk I just read that it takes up to about 2 hours to do. So I will be doing this tomorrow
                    It varies depending on how thick the plate is. The thicker it is the longer it takes to cool down between cycles. On my 300x300x6mm plate and 600w 120v heater it takes about 15 minutes to tune to 75c.
