    Solved Duet 2 wifi x-endstop staying triggered
    • JamesM
      JamesM last edited by
      I have been using a Duet 2 wifi in my ender 3 for a few years now and all of a sudden I'm having a problem with the x-endstop. I use the standard creality switches and it had worked flawlessly for a long time.
      The first thing I did was replace the actual microswitch but that made no difference. Even if I unplug the endstop wire from the board it still shows as triggered.
      Any ideas? I tried copying the sd card to a new one in case there was some corruption or whatnot but same result.
      Board: Duet WiFi 1.02 or later
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
      Duet WiFi Server Version: 1.23
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Nov 20 2018 17:45:20 GMT-0500 (Eastern Standard Time)
      G90                                      ; Send absolute coordinates...
      M83                                      ; ...but relative extruder moves
      M550 P"Ender 3"                          ; Set machine name
      M552 S1                                  ; Enable network
      M586 P0 S1                               ; Enable HTTP
      M586 P1 S1                               ; Enable FTP
      M586 P2 S0                               ; Disable Telnet
      M569 P0 S1                               ; Drive 0 goes forwards
      M569 P1 S1                               ; Drive 1 goes forwards
      M569 P2 S0                               ; Drive 2 goes backwards
      M569 P3 S1                               ; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1                  ; Configure microstepping with interpolation
      M92 X160.00 Y160.00 Z400.00 E846.90      ; Set steps per mm (gregs wade was 604 steps)
      M566 X500.00 Y500.00 Z30.00 E600.00      ; Set maximum instantaneous speed changes (mm/min)
      M203 X10800.00 Y9000.00 Z300.00 E10000.00 ; Set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z500.00 E3000.00  ; Set accelerations (mm/s^2)
      M906 X1600 Y1600 Z700.00 E960.00 I30 	 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                  ; Set idle timeout
      M208 X0 Y-9 Z0 S1                         ; Set axis minima
      M208 X230 Y235 Z200 S0                   ; Set axis maxima
      M574 X1 Y1 S1                            ; Set active high endstops
      M574 Z1 S2                               ; Set endstops controlled by probe
      M307 H3 A-1 C-1 D-1                      ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F180 T6000                    ; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X49 Y-1 Z1.66                   ; Set Z probe trigger value, offset and trigger height
      M557 X55:220 Y20:220 S20                 ; Define mesh grid
      M305 P0 T100000 B3950 R4700              ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                             ; Set temperature limit for heater 0 to 120C
      M305 P1 B4725 C7.060000e-8               ; Set thermistor + ADC parameters for heater 1 (old setting P1 T100000 B4138 R4700)
      M143 H1 S285                             ; Set temperature limit for heater 1 to 285C
      M307 H1 A322.3 C152.9 D3.2 V24.4	     ; PID AUTOTUNE INFO FOR E3D V6
      M106 P0 S0 I0 F500 H-1                   ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 H-1			    	 ; Set fan 2 value, PWM signal inversion and frequency.  Thermostatic control is turned off (for led lights)
      M563 P0 D0 H1                            ; Define tool 0
      G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
      G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
      • A Former User
        This post is deleted!
        JamesM 1 Reply Last reply Reply Quote 1
        • JamesM
          JamesM @Guest last edited by
          @arnold_r_clark
          I'm not looking to update this printer to 3.x firmware. I have it on one of my corexy printers but still use and like 2.5 on my ender 3 and other corexy.
          Good thinking on the second e driver. I had to check since I set up my ender with dual z steppers and leadscrews but I have them sharing the single z driver.
          Thanks!
          • JamesM
            Well, turns out it was a dang broken wire.
            Go figure...LOL.
            • Topic has been marked as a question  Phaedrux Phaedrux
            • Topic has been marked as solved  Phaedrux Phaedrux
