    BLTouch Initializing but Not Homing
    1.2k
    • jdzenderundefined
      jdzender
      Hi Everyone, I've been struggling with my BLTouch for a while now and I'm not sure what to try next. I've looked through the forums and no luck yet. Thank you in advance to any help, you guys are awesome!
      I'm using BLTouch 3 and Duet 2 wifi RRF 3.3. When I turn on my printer the BLTouch initializes and deploys/retracts twice, when that's complete it has a steady red light.
      I can deploy/retract the probe manually using M401 and M402 commands. When I manually deploy the probe the blue light turns on.
      The problem is after I've homed the X and Y axis and go to home the Z axis, it does not home. I can press on the probe and it does not stop the Z axis. When the probe goes to home the Z axis the probe deploys and the blue light turns on as expected, but it just doesnt stop the printer.
      My config.g code:
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Feb 24 2022 18:43:24 GMT-0800 (Pacific Standard Time)
      M575 P1 S1 B57600                              ; enable support for PanelDue
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Zender"                             ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X128 Y128 Z128 E128 I0                    ; configure microstepping without interpolation
      M92 X700.55 Y700.55 Z3103.00 E200.00           ; set steps per mm
      M566 X6000.00 Y6000.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z300.00 E1200.00      ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1200 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X200 Y210 Z300 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z1 S2                                     ;configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y30 Z2.5                           ; set Z probe trigger value, offset and trigger height
      M557 X15:190 Y15:195 S20                       ; define mesh grid
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                              ; define tool 0, F was -1 now 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      Homeall.g:
      ; called to home all axes
      G91                    ; relative positioning
      G1 H2 Z5 F6000         ; lift Z relative to current position
      G1 H1 X-205 Y215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y-5 F6000     ; go back a few mm
      G1 H1 X-205 Y215 F360  ; move slowly to X and Y axis endstops once more (second pass)
      G90                    ; absolute positioning
      G1 X15 Y-15 F6000      ; go to first bed probe point and home Z
      G30                    ; home Z by probing the bed
      ;G91                   ; relative positioning
      ;G1 Z5 F100            ; lift Z relative to current position
      ;G90                   ; absolute positioning
      code_text
      Homez.g:
      ; homez.g
      ; called to home the Z axis
      G1 X15 Y-15 F6000 ; go to first probe point
      M1222 Report:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9X6JA-JUNSN-6J9F8-3S86R-TUR7U
      Used output buffers: 3 of 24 (12 max)
      Static ram: 23876
      Dynamic ram: 75016 of which 12 recycled
      Never used RAM 15512, free system stack 184 words
      Tasks: NETWORK(ready,13.7%,243) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.8%,441) IDLE(ready,0.4%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:03:43 ago, cause: software
      Last software reset at 2022-03-31 20:24, reason: User, GCodes spinning, available RAM 12272, slot 0
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 26.6, current 26.8, max 27.6
      Supply voltage: min 12.2, current 12.3, max 12.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2022-03-31 20:28:40
      Slowest loop: 4.77ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.3ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.59ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address 48:3f:da:a6:c4:5c
      WiFi Vcc 3.39, reset reason Power up
      WiFi flash size 2097152, free heap 25112
      WiFi IP address 192.168.1.44
      WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Socket states: 4 0 0 0 0 0 0 0
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      I have the BLTouch plugged into pins 1,2, and 8 (heater 3) as shown in the setup wiki.
      Again thank you to anyone who can help!
      • fcwiltundefined
        fcwilt @jdzender
        @jdzender
        The self-test the probe does at power on tells you the probe is getting power.
        The fact that M401/M402 work tells you the probe is responding to the PWM signal generated on the exp.heater3 pin, as specified in the M950 command.
        I gather the probe pin retracts if you touch the pin when deployed.
        The fact that triggering the deployed probe does not halt Z movement suggests the signal from the probe is not reaching the zprobe.in pin, as specified in the M558 command.
        What is the Z probe reading in the DWC?
        Have you verified continuity from the probe to the zprobe.in pin?
        jdzenderundefined 1 Reply Last reply Reply Quote 1
          Photo of wiring?
          jdzenderundefined 1 Reply Last reply Reply Quote 0
          • jdzenderundefined
            jdzender @fcwilt
            @fcwilt Thanks for the quick reply!
            The probe does retract if you touch it when its deployed, and then when I touch it again it will start flashing red and the z will continue to move closer.
            1. DWC says:
            M558
            Z Probe 0: type 9, input pin zprobe.in, output pin nil, dive height 5.0mm, probe speeds 120,120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.032.
            1. How do I verify continuity?
            Thanks again! Sorry still very new to Reprap firmware.
            • jdzenderundefined
              jdzender @Phaedrux
              @phaedrux
              Blue is bltouch white, and green is black.
              • jdzenderundefined
                jdzender
                Wow... just realized my polarity was backwards, green and blue needed to switch. Sorry for the dumb questions.
                Thank you for helping guys!
