Solved CAN bus anomalies with 6HC and 3HC
@phaedrux said in CAN bus anomalies with 6HC and 3HC:
Start eliminating extras until you find the smoking gun.
Yup - working on it. Re-running the same ~12 hour print every day, changing one thing each time.
@adammhaile Those
M905
codes are usually a symptom of excessive load on the Pi - DCS sends them whenever a scheduled delay takes +5s longer than expected (the current acceptable maximum for a 4s delay is already set to 9s, so plenty of time) or when the datetime has been changed (hence the corresponding messages in theduetcontrolserver
journal).So it would be interesting to see what actually prevents DCS from getting computing power and/or IO access to linked libs. Just to exclude IO from/to the microSD card, you could temporarily copy the entire DSF directory to
/tmp
and run DCS from there (that is from the Pi's memory):cp -r /opt/dsf/bin /tmp/dsf sudo systemctl stop duetcontrolserver /tmp/dsf/DuetControlServer
Just be aware that you'll have to keep the terminal where you run this open, else a potential print would be aborted. If the same disconnects persists, it must be related to the CPU, memory, or kernel. It would be interesting to see what happens then.
@chrishamm Interesting - will keep that in mind.
Strangely the SD card speed test is exactly the same with the new Duet boards, new Pi, and new faster SD card (the one recommended above). So I'd say that test is a red herring. I'm currently seeing 150+ MB/s reads on this card from the Pi.Will test with DCS in RAM if my current batch of tests fail to rule anything out.
@t3p3tony @chrishamm @Phaedrux @dc42
Update: I've been stress testing the machine after swapping the Pi again and tweaking some of the wiring runs to help avoid signal noise. The last 4 days I've started a 12 hour print every morning so that I could have it printing as long as possible without having to leave it running while I'm asleep.The first 3 days went beautifully but today I got another of the same failures.
However, this time was a little different...Previously the SBC Pi was running a dhcp server to provide an IP for a direct ethernet connected Pi running android and a touch screen DWC interface.
I ditched that when I rebuilt the DuetPi Lite image and instead installed a small WiFi/Ethernet router. So now the SBC Pi and DWC Android Pi are wired to that and I can connect to the machine over it's own WiFi access point (this is so I can get to it at MRRF ).The advantage of this was that previously when it would fail, I would never be able to connect to the Pi over SSH which limited my ability to diagnose. But this time I could hit its ethernet connection (which, unlike the WiFi, doesn't go down when the failure occurs it would seem) via the WiFi router I added.
So that led me to digging into various system logs and eventually dmesg, where I found a stream of errors, such as these:
[31055.833034] ieee80211 phy0: brcmf_cfg80211_get_station: GET STA INFO failed, -110 [31062.393030] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110 [31064.953033] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110 [31064.953060] ieee80211 phy0: brcmf_cfg80211_get_station: GET STA INFO failed, -110 [31071.513043] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
And it was those that led me to this Duet Forum post:
https://forum.duet3d.com/topic/23889/pi4-network-disconnect
Now, the crazy thing is: they were seeing exactly what I was.
- SPI comms reset
- WiFi dropping
- Print stopping midway through and DWC showing it was done
- Using a Pi 4 with a Duet 3 (mini, but still)
Fortunately, they seem to have a solution! In that post they recommended not using 5Ghz networks and disabling the wifi power management features. From further research it seems that WiFi with 5GHz is somewhat of an ongoing issue with the Pi 4 and it will sometimes just kill WiFi when it shouldn't.... Now, why that seems to affect SPI, I have no idea. But they seem to be related...
While I could disable power saving on WiFi, the 2.4GHz network part was a problem for silly reasons with my home WiFi access point.
So, for now I've switched to only using ethernet and have connected a separate USB ethernet adapter for the connection between the SBC Pi and the DWC Android Pi.Whether or not this will also fix the problem for me... time will tell. I'll be back to long test prints tomorrow morning and let you know how it goes in a few days.
But so far this seems promising given they were seeing pretty identical symptoms. My fallback at this point is tearing a Pi 3B+ out of something else in my house and using that. I have another Duet 3 machine with a 3B+ and it's been rock solid. -
@adammhaile Thanks for the info, that's very good to know. When I build the next DuetPi image, I'll disable WiFi power saving by default.
@chrishamm said in CAN bus anomalies with 6HC and 3HC:
Awesome.
Silly request while you are in there... is there any chance you would considering setting up thedsf
user to have a home directory and default shell so that you can log into it?
With complex configurations, such as mine, it's extremely helpful to be able to ssh directly as that user. I currently useusermod
to do this on each Duet SBC I have and then will use Visual Studio Code's remote features to directly connect to thesd
directory contents over SSH. This has also allowed me to keep the entire config backed up on GitHub -
@chrishamm @dc42 @Phaedrux @T3P3Tony
Just wanted to follow up on this and let you know that, at this point, I'm quite confident we found the problem. So, thank you all for sticking with me through all the ups and downs of solving this. It's been a crazy ride for sure.
And hopefully with the patches made to the Pi image this won't be a problem for people in the future who want to use a Pi4. -
@adammhaile thank you for following up, and for your patience and help in finding the issue. Its only through such valuable (and patient!) feedback that we can support such a wide range of machines, configurations and uses.
@adammhaile Thanks again for the feedback - looks like I missed your previous question. You should be able to assign a default home directory to the
dsf
user (usermod -d /home/dsf dsf
) and allow it to log in (chsh -s /bin/bash dsf
+passwd dsf
). At least on DuetPi thepi
user should have access to thedsf
files as well. -
At least on DuetPi the pi user should have access to the dsf files as well.
Read yes, write no. And if I make a file via the pi user it seems that DWC doesn't see it. It was kind of weird... it didn't act quite right.
And yes, I did exactly what you said to make the directory and set the shell. Just thought there was no reason it couldn't be setup like that from the start
