    Endstop connections
    • YYCSparks
      YYCSparks last edited by
      Hey guys I am a little new to RepRap and Duet but I have a CNC machine based on a Duet 3 Mini that I built. I have a question on wiring, can I use the Thermister terminals for Endstop connectors?
      And if so what would that look like config wise?
      Second question if I wanted to use one the Fan headers to turn a Relay off an on for a spindle is that okay and again what might that look like config wise?
      Thank you.
      jens55 Nightowl 2 Replies Last reply Reply Quote 0
      • jens55
        jens55 @YYCSparks last edited by
        @yycsparks, no re using thermistor terminals, yes re using the fan headers to turn a relay on/off.
        My config foo is severely lacking so somebody else needs to assist with that
        • Nightowl
          Nightowl @YYCSparks last edited by
          @yycsparks This might help:
          https://codingblog.galcomp.net/2020/08/15/adding-a-relay-to-a-duet-2-to-switch-on-a-router-via-gcode/
          Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
          I'm still on my learning curve, so take everything I say with caution!
          RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
          YYCSparks 1 Reply Last reply Reply Quote 1
          • YYCSparks
            YYCSparks @Nightowl last edited by
            @nightowl999 thank you that looks perfect. Really appreciate it.
