    Wall Plotter / Polargraph
    Using Duet Controllers
    • kr15_ukundefined
      kr15_uk
      Ladies and gents,
      Found my old pen wall plotter aka Polargraph project and wondering if I could get it going on RRF?!
      If yes than could someone please point me to the article/KB I've managed to miss?!
      Ta
      Kris
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @kr15_uk
        @kr15_uk
        • What is a polarograph?
        • What kind of motors does it use?
        • What kind of geometry does it use?
        • How do you home it?
        • How does it print?
        kr15_ukundefined 1 Reply Last reply Reply Quote 0
        • kr15_ukundefined
          kr15_uk @alankilian
          @alankilian It’s your typical wall mounted pen plotter with 2x motors in each top corner with pen suspended in between.
          Motors, endstops etc at this point are irrelevant really, I need to get geometry 1st which I’m not sure what it is.
          GRBL calls it v-plotter, marlin have recently added specific “kinematic setting” called polargraph…
          Hope this explains it a bit better.
          Ta
            droftarts administrators @kr15_uk
            @kr15_uk the hangprinter kinematic may support a polargraph; a hangprinter is like a 3D polargraph. I’m not sure if you can just define two motor points, or whether the hangprinter kinematic may need to be adapted to support polargraph (one for @dc42 !) to allow support.
            See https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_Hangprinter
            • droftartsundefined droftarts referenced this topic
