    Bad Wifi Module on New Duet 2 Wifi
    163
    • Alijambo73
      Alijambo73 last edited by
      I just replaced an older duet 2 wifi board that lost its 5v supply. When I mount the new board in the box the wifi led goes out and when I restart the board it won't even try to connect. If I remove it it will connect again but seems to have issues maintaining the connection.
      My guess is a bad wifi module. Any other thoughts?
      4/12/2022, 10:13:08 AM M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 0JD0M-9P6B2-NJ4S4-6JKDA-3S86K-KB16L
      Used output buffers: 3 of 24 (14 max)
      Static ram: 23460
      Dynamic ram: 74740 of which 88 recycled
      Never used RAM 13792, free system stack 178 words
      Tasks: NETWORK(ready,179) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,417) IDLE(ready,20)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:09:26 ago, cause: power up
      Last software reset at 2022-04-11 18:58, reason: User, GCodes spinning, available RAM 13792, slot 1
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 18.6, current 20.0, max 20.5
      Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0, standstill, SG min/max not available
      Driver 6: position 0, standstill, SG min/max not available
      Driver 7: position 0, standstill, SG min/max not available
      Driver 8: position 0, standstill, SG min/max not available
      Driver 9: position 0, standstill, SG min/max not available
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2022-04-12 10:13:06
      Cache data hit count 685983135
      Slowest loop: 129.96ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 6.0ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 57.13ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(4) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address 48:3f:da:a6:83:44
        WiFi Vcc 3.46, reset reason Power up
        WiFi flash size 2097152, free heap 24400
        WiFi IP address 192.168.1.221
        WiFi signal strength -77dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        Socket states: 4 2 0 0 0 0 0 0
        === DueX ===
        Read count 1, 0.11 reads/min
        4/12/2022, 10:11:35 AM Connection established
        4/12/2022, 10:11:32 AM Connection interrupted, attempting to reconnect...
        HTTP request timed out
        4/12/2022, 10:03:51 AM Connection established
        4/12/2022, 10:02:58 AM Connection interrupted, attempting to reconnect...
        Network error
        4/12/2022, 10:02:45 AM Connection established
        4/12/2022, 10:02:37 AM Connection interrupted, attempting to reconnect...
        4/12/2022, 10:01:11 AM Connection established
        Phaedrux Moderator @Alijambo73 last edited by
        @alijambo73 said in Bad Wifi Module on New Duet 2 Wifi:
        The signal strength is quite bad.
        What kind of a box is it?
        What is the signal strength outside of the box?
        What was the signal strength of the old board?
        • Alijambo73
          It's a pla box that the original board has worked great in for a few years now. I'm confident the box is not the issue. Still looking for an explanation of why wifi goes dead when mounted. I think the weak signal and the complete loss of any function when mounted point to a bad wifi module.
          • elmoret
            elmoret last edited by elmoret
            On the Duet WiFi v1.05, the Wifi module was changed. This could result in what you're observing, if the signal was very weak/borderline to begin with.
            If the reading above is without the PLA box, I'm not surprised that adding a few mm of plastic would cause it not to connect - it would be taking a weak signal and making it even weaker. I don't see how it is the boards fault if mounting it in a box is what "breaks" it.
            elmoret 1 Reply Last reply Reply Quote 0
            • elmoret
              elmoret @elmoret last edited by elmoret
              To add on to my comment above: -77dBm is quite weak:
              https://www.metageek.com/training/resources/wifi-signal-strength-basics/
              At -80dBm, one should expect inconsistent connection/packet delivery. A few mm of plastic is worth 5-6 dBm of signal loss.
              Can you move the printer closer to the router? How far is it currently, and through how many walls?
              • Alijambo73
                The problem was some bad solder connections on the wifi module.
                  Were you able to touch them up?
                  Alijambo73 1 Reply Last reply Reply Quote 0
                  • Alijambo73
                    Alijambo73 @Phaedrux last edited by
                    @phaedrux I didn't but I have a te h who did.
