    Stringing with PLA
    32
    2.0k
    • Toddmundefined
      Toddm @infiniteloop
      @infiniteloop I tend to agree with you. I was watching it put down a first layer and the extrusion is inconsistent, some of it is obviously squeezing out past the nozzle making a wider track and bunching up and some of it is just barely stringing and not even bonding to the bed. I was trying to figure out if it was related to speed or just the extruder. This printer is not very rigid in my opinion, but slow speeds like you mentioned should be ok I would think? I tightened all the bolts holding the uprights to the base and the top a few weeks ago. The rounded off square print above was printed at 30mm/s at the fastest. The outer layer was only 15mm/s ( I missed that in the slicer settings, intending it to all be 30mm/s). I have also thought about moving the extruder from the top of the machine to about halfway down so I can use a shorter bowden tube. Its about 700mm right now. The frustrating thing is that this printer worked a few months ago before all of the upgrades (aside from stringing), but the stock PEEK heatsink in the hot end melted and destroyed the hot end. That was why I decided to upgrade everything. That might have been a mistake!
      I have some older PETG and various other spools of PLA. The white PLA I'm using was fresh out of the bag a few weeks ago after I gave up on the older spool I was using. The new spool made no difference.
      Last night I read that a partially clogged nozzle could possibly cause this. I have noticed that if I just extrude plastic at the max rate, about 6.5mm/s that it almost always curls back to the tip of the nozzle and it will also get really thick after a few seconds especially after the end of the plastic makes contact with the bed. I am running it really hard at that point, the extruder will start skipping at 6.7mm/s. While taking the nozzle out I broke the ground wire to the hot end fan. Now I need to find a way to release the broken pin so I can crimp on another one. Once the wire broke, I shut it off and walked away.
      infiniteloopundefined jens55undefined 2 Replies Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @Toddm
        @toddm said in Stringing with PLA:
        Sorry for the lack of luck with your printer - more than enough reasons to walk away. I had a similar run when I started to print with a fresh roll of PETG - never had problems with PETG so far, but with that material, everything went wrong. I ended up with wild theories, replaced many parts of my print head (and some other mechanics as well), tried zillions of adjustments in RRF - to no avail. With some PETG from another manufacturer, the problems finally vanished over night.
        PLA is more forgiving, but more hygroscopic as well. Old PLA can often be revived by drying it at around 50 °C in an oven for 4-6 hours. But if the manufacturer can’t hold the diameter within very narrow limits, you have no chance to get a proper extrusion. Happened to me.
        The good thing about those struggles is that we learn a lot about our printers - one thing, for example, is to print slowly in order to achieve good quality for cheap. 20 vs. 40 mm/s can make a huge difference with fine details. Of course, a long bowden (mine has 700 mm, too) promotes stringing, but in your case, that is a secondary problem.
        First, bring up your hotend again. Then, use some other filament. This is especially true if you encountered a partially clogged nozzle: you’re right with your suspicion, that can cause all kinds of trouble - but it should not happen at all, as long as the chemistry of the filament works. If not, some ingredients burn to debris which accumulates on the walls of the heat break and the nozzle itself.
        One final thought: In most cases, even the most complex intricacies have a simple reason - which you will know when you find it 😊 . Wish you luck on that way. 👍
        Toddmundefined 1 Reply Last reply Reply Quote 0
        • jens55undefined
          jens55 @Toddm
          @toddm, I have found out that the point where the extruder skips is not the limit. Even before that, you run into irregularities with flow. Having said that, if 6.7 mm/sec gives you extruder skipping, I would think 5 mm/sec should be safe.
          I would also check the entire filament path - how easy is it for the extruder to pull filament off the spool? A long Bowden tube can introduce a lot of friction and how easy does the spool unroll? Have you checked tension on your feed rollers? You could have insufficient pinch pressure on the feed rollers introducing variable flow.
          30 mm/sec should be achievable by a printer built with chop sticks 🙂
          You could try a 'cold pull' on the nozzle. I would be tempted to remove the nozzle and see if filament easy easily pushed through the print head - there should be no obstruction with the nozzle removed. You could try a new nozzle or, if you have a brass nozzle and a plumbers torch handy, burning out the nozzle always clears things up for me.
          Anther, less likely reason for inconsistency - Is your slicer set to the right filament diameter (I overlooked that once)?
          Looking at your pictures, it seems that filament is laid down properly in one direction but the layers get really bad in another direction - that would seem to indicate mechanical slop in one direction but not the other. I think I would tend to ignore mechanical issues with head positioning at this point and try to concentrate on one issue at the time which would be filament flow. There are a lot of possible problem areas in a 3D printer and unless you tackle them one by one it can get very overwhelming and basically impossible to work out what is going on.
          Good luck .... don't tear out too many hairs during trouble shooting ....
          • Toddmundefined
            Toddm @infiniteloop
            @infiniteloop Thanks for all of your suggestions and encouragement! I fixed the wiring and loaded up my spool of PETG, made the slicer print everything at 30mm/s and got this:
            This looks much better to me. One side had a small section where the layers didn't bond very well, but overall it makes me happy! I didn't even calibrate the extruder! It needs some tuning still but at least its consistent! I need to find some better PLA. I'll probably throw what I have in the vacuum oven for a bit, but I think its probably a lost cause.
            jens55undefined infiniteloopundefined 2 Replies Last reply Reply Quote 1
            • jens55undefined
              jens55 @Toddm
              @toddm that does indeed look a lot better. I wonder why there appears to be diagonal lines on the verticals.
              There also seems like a bit of under extrusion between the brim and the model in your first picture.
              Looks like there needs to be some pressure advance tuning to improve the vertical seam.
              The bottom line though is that you have something that you can work with! Good show!
                infiniteloop @Toddm
                @toddm Great! As @Jens55 said, now you have something to work with. Some lack of layer bondage (plus a certain brittleness) is a known problem with PETG - well, with some of those filaments. It’s all about the chemistry: colours, add-ons, … I’ve finally found a filament with good layer adhesion, mechanical stiffness and elasticity - a perfect match with the characteristics of my printer. With PLA, that’s less difficult, good idea to try some other brands.
                The diagonal pattern @Jens55 already mentioned is an indicator for some mechanical problem, but I can’t help you with that: you have a fancy Delta, my poor old bed-slinger is quite different … Maybe you should follow @Phaedrux’s advice and post a video of your printer in action? I suggest you start a new thread on this.
                Finally, thank you for the imagery: made my day to see such a progress!
                Toddmundefined jens55undefined 2 Replies Last reply Reply Quote 0
                • Toddmundefined
                  Toddm @jens55
                  @jens55 I think that separated when I pulled it off of the bed. I wasn't very gentle because I wanted to see how the layers stuck together. I definitely have some issues with the flatness of the glass bed which isn't helping that either.
                  • Toddmundefined
                    Toddm @infiniteloop
                    @infiniteloop This color and reflectivity made it hard to take pictures. In person in looks smoother than the pictures would indicate. It definitely does have some angled lines and texturing. Per @Phaedrux's advice I did take a video of it. I think I will start a new thread as you suggest since this isn't really about stringing or PLA anymore.
                    I'm also seriously thinking about cutting out a metal frame on my boss's laser to help with the rigidity. This printer was given to me and I think the age and the tab and slot melamine frame is close to its expiration.
                    Thanks to everyone who posted! I read them all even if I didn't reply directly.
                    jens55undefined 1 Reply Last reply Reply Quote 0
                    • jens55undefined
                      jens55 @Toddm
                      @toddm lol ... tab and melamine frame .... I had no idea how close I was when I said that even a printer made with chop sticks should be able to do 30 mm/sec.
                      • jens55undefined
                        jens55 @infiniteloop
                        @infiniteloop said in Stringing with PLA:
                        I have never seen a PETG filament that had layer bondage and brittleness. Those are PLA issues and not PETG issues. PETG has stringing issues instead. I suppose it is possible to get that with PETG as well if you have setup issues or bad filament but I would not call it a 'known problem'.
                        infiniteloopundefined 1 Reply Last reply Reply Quote 0
                          infiniteloop @jens55
                          @jens55 said in Stringing with PLA:
                          … but I would not call it a 'known problem'
                          What term do you suggest: 'unknown Problems'? Why then is the web full of pages dealing with the problems I named? 😀
                          • jens55undefined
                            @infiniteloop, while I can't say that I have heard or read about great inter layer adhesion in 53.75 cases and 5.037 times about adhesion failure, my overall 'feeling' and 'understanding' is that PETG has much better inter layer adhesion than PLA. Also, PLA has, IMHO, a much higher incidence of brittleness.
                            In addition to what I have read about others having experienced, both of these characteristics are well supported by my own experience.
                            Feel free to disagree with me. Both views are anecdotal to a large degree as I am not aware of definitive studies on these subjects (although there might well be).
                            Late edit: Maybe you and I are just reading different web pages ?
                            • jens55undefined
                              jens55
                              I did a bit of searching and found this article interesting:
                              https://www.3dprintbeast.com/what-causes-poor-petg-layer-adhesion/
                              It lists a number of causes for inter layer adhesion issues... and yes, you can screw up anything if you do not set up your printer correctly for the material you are printing with.
                              A quote from the article:
                              Poor PETG layer adhesion is perhaps the best example of such an issue, with many enthusiasts switching to PETG filament to benefit from its naturally strong layer adhesion capabilities but being greeted with the complete opposite.
                              The key being the 'natural strong layer adhesion' and experiencing failures due to poor printing practices.
                                @jens55 I read more than I write, so I learned a lot about PETG problems - and how to solve them. In short: had I used the word ‘properties’ instead of ‘problems’, you were right. Stringing is such an unwanted property of PETG which is hard to avoid, except of by design of your parts. Maybe we can agree on this. In addition, we should agree not to capture someone else’s thread.
                                • jens55undefined
                                  @infiniteloop Agreed! Also I didn't intend to take over the thread, I just wanted to make sure that the OP didn't get the wrong (IMHO) idea about PETG.
                                  Anyway, we are all good .... at least from my end 🙂
