    Toolboard + fixed fan
    • tecno
      tecno last edited by
      How do I change following to have the tool fan always on! No M106 to touch this !!!
      M950 F1 C"121.out2" ; // TOOL FAN
      M106 P1 S1 H-1 ;
      Must be 100% ON >>>> NO M106 to tamper this
      As there is no power output=Vin connector need to have C"121.out2" to do this for me.
      tecno 1 Reply Last reply Reply Quote 0
      • tecno
        tecno @tecno last edited by
        I think I have a solution for my needs, please correct me if I am wrong.
        M950 P0 C"121.out2"
        M42 P0 S1
        So why a problem, S3D posts gcode with M106 S0 and I do not want to manually edit each and every print I want to do.
        • oliof
          oliof last edited by
          If you used OUT1, you could use the GND pin rather than out1 and you should have an always on fan.
          <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
          • tecno
            tecno @oliof last edited by
            @oliof
            Out1 is set for part cooling, yes it would be so as you describe but I am out of these bloody miniature crimp connectors so a switch is not possible 😉
            • Referenced by  tecno tecno
