BLTouch Not working Duet 2 WIfi
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 23 2022 21:56:24 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Creality CR6SE w/ BLtouch" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z250 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
T0 ; select first toolbolded text -
@quinn I'd suggest revisiting the configurator, you've not got any of the correct config for BLTouch in there.
Which pin are you using as the servo control?
Can you send M122 and M98 P"config.g" and post the results? This will give us some basic information needed to help further.
What exactly isn't working?
If you send M401 and M402 does the pin go in and out?
Does the pin go in and out at power up?@quinn said in BLTouch Not working Duet 2 WIfi:
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speedThis line itself is not correct for a BLTouch. So as @Lo-Fi says revisit the config tool and choose the options for BLTouch.
@lo-fi I want to but the board won’t connect to my computer anymore. The port is not transferring data.
@phaedrux
Here is what is stated.=== Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later<LF>Board ID: 0JD0M-9P6M2-NWNS0-7J1FL-3SJ6K-T907K<LF>Used output buffers: 1 of 24 (1 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 92704 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 12400<LF>Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,4252) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:01:14 ago, cause: power up<LF>Last software reset at 2022-04-18 08:57, reason: User, spinning module GCodes, available RAM 11976 bytes (slot 3)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 19.2, current 21.6, max 21.9<LF>Supply voltage: min 1.2, current 1.5, max 1.6, under voltage events: 0, over voltage events: 0, power[Warning: Maximal number of characters per line exceeded! Check the line break settings in Terminal > Settings > Text or increase the limit in Terminal > Settings > Advanced.]
I have tried rebuilding the entire file. I tried a new cable and now I can connect yat to the motherboard. I have a new issue though. I can't seem to get the web control to work even rebuilding using the config tool. Any suggestions.
Ok so it looks like the board has firmware 2.05.1 on it which is quite old now. But your config file syntax is for the more recent reprapfirmware 3. Not that it would matter for your bltouch because your config has no commands related to bltouch either way.
I'm not sure what you mean here. It looks like you were able to use YAT to send commands at least.
It looks like you have the board connected to the wifi network GUEST. Is that your main network? If that is a guest network and you're trying to connect to it from your computer you may not be able to reach it because routers usually keep the guest network separate.
My normal wifi won't let the board connect because it is 5mhz but the 2.5 I separated into a guest for other pieces of equipment in my apartment it is just named guest but it is not set up as a guest. I found my first cable did not have a proper connection so I got a new cable now it works but is requesting a restart every time I try getting it to connect. I want to update to riprap 3.3 but I cant seem to get it to work. @phaedrux
I can't seem to get past this error how can I fix this? @quinn
What error do you mean? Your image seems to show it's connected to the wifi correctly and I don't see any other errors.
Are you able to connect to DWC now or not? Can you show a photo of what you're seeing now?
I need more details about what is and is not working right now first. If you have access to DWC updating the firmware is pretty straightforward and involves uploading a few zip files to the system tab.
If you still have access to DWC. Upload these 4 zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
That will get your firmware and DWC up to date. -
Phaedrux
