    Failed to upgrade firmware
    602
    • brianundefined
      brian
      As i was upgrading from 3.3 to 3.4 we had a power outage, the upgrade had removed all file from the sd card. I put in a backup card and the duet2 wifi is working but i fail to connect to the internet. Can anyone tell me what to do next?
      • brianundefined
        brian
        I now get this error message: Error: M587: Failed to add SSID to remembered list: another SPI transfer is pending
        • brianundefined
          brian
          There is also and error message: config override.g file missing
            Can you send M122 by USB terminal and post the response here?
            At what point were you at when the power went out? What method were you using to update?
            brianundefined 1 Reply Last reply Reply Quote 0
            • brianundefined
              brian @Phaedrux
              @phaedrux
              The file system showed no files when lights went out. M122;
              m122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
              Board ID: 0JD0M-9P6B2-NJ4S8-6JKF6-3S86R-1A7GL
              Used output buffers: 1 of 24 (12 max)
              Static ram: 23876
              Dynamic ram: 75032 of which 188 recycled
              Never used RAM 15320, free system stack 185 words
              Tasks: NETWORK(ready,8.0%,521) HEAT(suspended,0.0%,330) MAIN(running,92.0%,305) IDLE(ready,0.0%,29), total 100.0%
              Owned mutexes: USB(MAIN)
              Last reset 00:29:54 ago, cause: power up
              Last software reset at 2022-04-18 08:38, reason: User, GCodes spinning, available RAM 15496, slot 2
              Error status: 0x00
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 31.2, current 31.3, max 31.8
              Supply voltage: min 0.5, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
              Driver 0: position 0, ok, SG min/max not available
              Driver 1: position 0, ok, SG min/max not available
              Driver 2: position 0, ok, SG min/max not available
              Driver 3: position 0, ok, SG min/max not available
              Driver 4: position 0, ok, SG min/max not available
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Slowest loop: 101.05ms; fastest: 0.14ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 3.2ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is ready with "m122" in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 1.02ms; fastest: 0.00ms
              HTTP sessions: 0 of 8
              • WiFi -
                Network state is starting2
                WiFi module is disabled
                Failed messages: pending 0, notready 12, noresp 0
                ok
              • brianundefined
                brian
                To clarify, the power went out a minute or so after starting.
                  It looks like the main firmware is at 3.3 and the wifi module isn't started, and perhaps needs the wifi firmware reflashed as well.
                  Try sending
                  M552 S-1
                  M552 S0
                  M552 S1
                  and see what it says each time.
                  Then try sending M997 S1 to reflash the wifi module and see what it says.
                  • brianundefined
                    brian @Phaedrux
                    @phaedrux Worked like a charm. Thank you very much. Wonder why isnt this in the documentation?
                    • brianundefined
                      brian
                      @brian However, i now have this error: Phaedrux MODERATOR 18 Apr 2022, 21:30
                      Try sending
                      M552 S-1
                      M552 S0
                      M552 S1
                      • brianundefined
                        brian @brian
                        Now after uploading files :
                        Error: M997 S0 Firmware binary "0:/firmware/Duet3CombinedFirmware.bin" not found.
                        Even after uploading this file?
                          @brian which version of DWC is currently running? You can find out on the Settings/General page.
                          • brianundefined
                            brian @dc42
                            @dc42 WDC 3.4.0 I was able to get it working by copying the file to the sd card and then running the upload again. Then right away had timeout issues as soon as a print started but been through that before so replaced M307 line, with M307 H1 A350 C500 D50 B1. Everything seems to v3.4 now. So hopefully all is well.
                              Now that you have access to DWC again the best way to insure you have all the correct files in the correct places for future updates is to upload the main firmware zip file to the system tab in DWC.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
                              Upload the zip file as is, do not extract it first. It will reflash all the firmwares and update all the DWC files. Next time you need to update firmware use the same technique of uploading the main release zip file for best results.
                              • brianundefined
                                brian @Phaedrux
                                @phaedrux Thank you, i will do that.
