    "Lost" retract.
    • vapvap
      vapvap last edited by
      After a break in printing, I found that the retract stopped working in the files generated by the slicers (during the retract, the short sound of a stalling motor). But if I generate the g-code from the site teachingtechyt.github.io, everything works fine.
      My CONFIG.G:
      ; generated by RepRapFirmware Configuration Tool on Mon Aug 06 2018 00:13:45 GMT+0100 (IST)
      G90                             ; Send absolute coordinates...
      M83                             ; ...but relative extruder moves
      M555 P1                         ; Set firmware compatibility to look like RepRapFirmare
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R105.6 L288 B105 H250       ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                   ; Put your endstop adjustments here, or let auto calibration find them
      M550 PMy printer                ; Set machine name
      M552 S1                         ; Enable network
      M586 P0 S1                      ; Enable HTTP
      M586 P1 S0                      ; Disable FTP
      M586 P2 S0                      ; Disable Telnet
      M569 P0 S0                      ; Drive 0 goes forwards
      M569 P1 S0                      ; Drive 1 goes forwards
      M569 P2 S0                      ; Drive 2 goes forwards
      M569 P3 S0                      ; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1         ; Configure microstepping with interpolation
      M92 X80 Y80 Z80 E2727           ; Set steps per mm
      M566 X370 Y370 Z1200 E40	   ; Set maximum instantaneous speed changes (mm/min)(Jerk)
      M203 X12000 Y12000 Z12000 E1200 ; Set maximum speeds (mm/min)
      M201 X3000 Y3000 Z1000 E120    ; Set accelerations (mm/s^2)
      M204 P4000 T2000 ;  Set accelerations for print and travel moves (mm/s^2)
      M906 X1000 Y1000 Z1000 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                         ; Set idle timeout
      M208 Z0 S1                      ; Set minimum Z
      M574 X2 Y2 Z2 S1                ; Set active high endstops
      M558 P5 R0.4 H2 F1200 T6000     ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1            ; Set Z probe trigger value, offset and trigger height
      M557 R90 S20                    ; Define mesh grid
      M307 H0 B0 S1.00                ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 C0 R4700  ; *Set thermistor + ADC parameters for heater 0
      M143 H0 S120                    ; *Set temperature limit for heater 0 to 120C
      M305 P1 B4725 C7.060000e-8      ; *Set thermistor + ADC parameters for heater 1
      M143 H1 S280                    ; *Set temperature limit for heater 1 to 280C
      M106 P0 S0 I0 F25000 H-1          ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 H-1          ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F2                  ; Define tool 0 + DEFAULT Fan0 ->forwarded to-> Fan2!!!
      G10 P0 X0 Y0 Z0                 ; Set tool 0 axis offsets
      G10 P0 R0 S0                    ; Set initial tool 0 active and standby temperatures to 0C
      T0                              ; Select first tool
      M501				; new commands override the ones earlier in your config.g
      G-code from teachingtechyt.github.io:
      retraction.gcode
      G-code from PrusaSlicer:
      Mask_hook.gcode
      Tell me please, what should I do to make the retract work in the slicer?
        It looks like Mask_hook.gcode is setting pressure advance, so that may explain the difference in sound as the extruder is already reversing before the retraction occurs.
        vapvap 1 Reply Last reply Reply Quote 0
        • vapvap
          vapvap @Phaedrux last edited by
          @phaedrux
          It seems I understand what's going on.
          I have a remote extruder installed with a recommended acceleration value of 120. If this value is lowered a little, the retract starts working correctly. I also noticed that this happened when the retraction speed was above 30mm/s.
          The only thing I still don’t understand is why everything was without problems during the calibration tests?...
