    DUEX 0.11 FAN 5
    Gcode meta commands
    2.7k
    • paolozampini1973undefined
      paolozampini1973 @oliof
      @oliof I wanted to ask you but there is an algorithmic auto for temperatures because I don't like the one I have at all I would like that there would be an algorithmic auto that, based on the temperature that rises and falls, the rule automatically
      • oliofundefined
        oliof
        I don't fully understand your request. Is this still about the fan to cool the stepper, or some other issue?
        paolozampini1973undefined 2 Replies Last reply Reply Quote 0
          @oliof said in DUEX 0.11 FAN 5:
          M307 H1 R2.300 C135.000:111.161 D12.60 S1.00 V25.0 B0 I0
          I do not speak the regulation of the nozzle temperature I now have an algorithm that I created that is stable but when I suddenly increase the speed the temperature drops by 2 degrees even by degrees
            @oliof temperature excursion exceeded 15.0°C this parameter can be changed instead of 15 degrees to have 20 degrees ?
            • oliofundefined
              oliof @paolozampini1973
              @paolozampini1973 after you update to 3.4, you can try heater feedforward https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m309-set-or-report-heater-feedforward which raises the heater power for higher speed prints.
              Alternately you can adjust the heater fault detection using M570 https://docs.duet3d.com/User_manual/Reference/Gcodes#m570-configure-heater-fault-detection but since this is a critical safety feature I would only use this as a last resort. It does allow you to adjust the excursion limit as you requested.
              paolozampini1973undefined 1 Reply Last reply Reply Quote 1
                Thanks for the very kind reply
