    DUEX 0.11 FAN 5
    Gcode meta commands
    2.8k
      dc42 administrators @paolozampini1973
      @paolozampini1973 so you are looking to turn a fan on when an external driver enable pin is activated, and off when it is deactivated.
      I think you can do that in RRF 3.4.0 by pretending that the fan is a motor brake solenoid. Use the M569.7 command https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m5697-configure-motor-brake-port to associate that fan port with the motor.
      paolozampini1973undefined 1 Reply Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @dc42
        @dc42 said in DUEX 0.11 FAN 5:
        the command 569.7 is not very clear how to use it there is a bit of confusion can you help me please I'll publish my config.g
        config (33).g
          paolozampini1973 @paolozampini1973
          @paolozampini1973 said in DUEX 0.11 FAN 5:
          config (33).g
          @dc42 Good evening can you help me please
            Why not use a thermistor attached to the motor? Then you can also see what the motor temperature actually is to know if it's an issue or not. You're trying to make this the more complicated than necessary.
            paolozampini1973undefined 3 Replies Last reply Reply Quote 0
              paolozampini1973 @Phaedrux
              @phaedrux said in DUEX 0.11 FAN 5:
              for the simple reason that I would have to make a structural change AND in any case it would not be 100% reliable it would be 96% reliable and also because I have to use the same rule for other things other functions
                your solution is much cheaper but much more complicated and then I haven't solved all the problems. Anyway, thanks for your interest
                  the simplest solution is also to leave the fans on all the time
                  • oliofundefined
                    oliof @paolozampini1973
                    @paolozampini1973 I cannot find PIN17 in the list of official pin names. can you point me to wjhere that is and what it's name is in the documentation? I seem to be looking in the wrong place.
                    • oliofundefined
                      oliof @oliof
                      OK, I did read the documentation and I believe dc42 would like you to add the following to config.g instead of a normal fan definition for fan5. Assuming this is for motor number 7:
                      comment out the following lines from your config.g (lines 90 and 91):
                      M950 F5 C"duex.fan5" Q500                            ; X create fan 1 on pin fan1 and set its frequency
                      M106 P5 S1 H-1                                       ; set fan 1 value. Thermostatic control is turned on
                      make it that they look like this
                      ; M950 F5 C"duex.fan5" Q500                            ; X create fan 1 on pin fan1 and set its frequency
                      ; M106 P5 S1 H-1                                       ; set fan 1 value. Thermostatic control is turned on
                      then, add the following line to your config.g (assuming driver 7):
                      M569.7 P0.7 C"duex.fan5"
                      restart your machine, make a move that uses motor 7. if the fan turns on while the motor is active, this setting works. If the fan is on when the motor is inactive and turns off when motor 7 works, change the M569.7 like this:
                      M569.7 P0.7 C"!fan0"
                      Note that this will always turn the fan on fully and that I have not tested this function myself.
                      paolozampini1973undefined 1 Reply Last reply Reply Quote 2
                        paolozampini1973 @oliof
                        @oliof said in DUEX 0.11 FAN 5:
                        30/4/2022, 18:38:03 M569.7 P0.7 C"fan5"
                        Warning: M569.7: Command is not supported
                        30/4/2022, 18:37:12 M569.7 P0.7 C"duex.fan5"
                        Thanks for your reply but the command is not supported
                          @paolozampini1973 from my original post:
                          paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                            so i should upgrade
                            The problem is that with my configuration I don't know what it means to me at What problems do I run into after what changes I have to make
                            am have RRF 3.3.0
                              my 3D printer now works very well however if I do the upgrade What are the changes I have to do next ?
                              • oliofundefined
                                @paolozampini1973 read the upgrade notes and make any required updates to your configuration: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-340
                                Other than adding macros for heater fault I did not change a single thing on my machine, but yours is different and may need adjusting.
                                paolozampini1973undefined 1 Reply Last reply Reply Quote 1
                                  Ok I will read And anyway I will make a complete backup of the memory in case I should have problems I can go back
                                  • oliofundefined
                                    @paolozampini1973 backups are always a good idea. I have my configurations under version control and stored on github for easy reference and to make sure that in the case of local catastrophe I have a copy available elsewhere.
                                      I'll probably do this upgrade tomorrow as temperatures and speeds improve what your opinion is ?
                                      • oliofundefined
                                        I am running my printers very conservatively, so I do not go for maximum speed.
                                          I believe that a printer once that makes 70 - 80 mm is more than enough important to have the accuracy is the quality
                                            Ultimaker Cura Enterprise 4.10.0 I don't know if you've ever tried it but the prints are much higher quality and the processing takes about 20% less
