    Motors not reacting
    • Hammadundefined
      Hammad
      Hello experts,
      I am having a problem with my setup.
      The setup is a Duet3 6HC with 3 1XD modules that are connected to stepper motors from Nanotec. Link to the Motors:
      Nanotec Stepper Motors
      I'm still getting no response from the motors even after upgrading the firmware to 3.4 to solve the issue with 1XD modules. To check the motors I used an Arduino Uno with grbl and the motors moved. I still can't figure out why the motors won't respond to the Duet3 setup. I checked the wiring and every bit of the documentation. Any idea what could be the problem?
      I also tried forcing the axis to report as homed and the motors still won't move. The coordinates on the touchscreen (Panel 7) change when I try to move the axis but the motors aren't moving at all.
      Extra info:
      The limit switches are in NC setup.
      There will be no heated bed or fans in this printer
      The Mainboard will not use Ethernet.
      thanks for the support!
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • Hammadundefined Hammad referenced this topic
      • alankilianundefined
        alankilian @Hammad
        @hammad
        OK, those are a new set of motor/drivers for me.
        Can you please post:
        • Your complete config.g
        • A diagram of how you have the motors wired to the Duet.
        • A diagram showing any other wiring to the motors such as power, enables etc.
        • A link to the manual for the exact motor/driver you are using.
          Can you also post the results of M122 and M122 B# where # is the can bus address of each of the expansion boards?
          Hammadundefined 1 Reply Last reply Reply Quote 0
          • Hammadundefined
            Hammad
            This post is deleted!
            • Hammadundefined
              Hammad @Phaedrux
              • Hammadundefined
                Hammad
                I found the error... 2 1XD Boards had the same address and it was causing the whole problem. Thanks for the support!
