    Solved Part cooling fan and extruder fan are constantly on
    • AlecSanchez
      AlecSanchez last edited by AlecSanchez
      I am trying to set up my part cooling fan and extruder fan, but it appears that out4/5/6 on my board are constantly on. It is a Duet 3 MB 6HC, and the jumper for out4/5/6 is jumped for 12v. The fans I am trying to run are also 12v. M106 is giving me no control over them also. Any help would be greatly appeciated! attached is my config.g file also
      config.g
        The config looks ok
        M950 F0 C"out5" Q500                      ; create fan 0 on pin out5 and set its frequency
        M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"out6" Q500                        ; create fan 1 on pin out6 and set its frequency
        M106 P1 S0 H-1                           ; set fan 1 value. Thermostatic control is turned off
        M563 P0 D0 H1 F0                             ; define tool 0
        Have you tried setting up with one of the other outputs?
        Photo of the wiring?
        It's possible the mosfets are damaged and failed fused in the on position.
        AlecSanchez 1 Reply Last reply Reply Quote 0
        • AlecSanchez
          AlecSanchez @Phaedrux last edited by
          @phaedrux Thank you for the reply. I have tried all of the outputs 4/5/6, which are all of the PWM controllable outputs to my knowledge. Attached is a picture of the extruder fan and part cooling fan wired to output 5/6Duet 3 Fans.jpg
          Rushmere3D 1 Reply Last reply Reply Quote 0
          • Rushmere3D
            Rushmere3D @AlecSanchez last edited by Rushmere3D
            @alecsanchez
            You have them wired incorrectly, you want the 2nd and 4th terminal.
            Check the wiring diagram here, https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram.
            Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
            AlecSanchez 1 Reply Last reply Reply Quote 1
            • AlecSanchez
              AlecSanchez @Rushmere3D last edited by
              @rushmere3d Ah I see it was wired to v_in + gnd thats why it was always on with no control. Thank you so much! They are working fine now
              • Topic has been marked as a question  dc42 dc42
              • Topic has been marked as solved  dc42 dc42
