Solved Stepper Motors Not Working As Expected
Hello, my stepper motors aren't working. I already made sure that the phases and wiring are correct. When I home ANY axis, the axis moves a little bit, but not smoothly, and then throws error "Phase A may not be connected"
undefined TRATOON marked this topic as a question
@tratoon Also, yesterday, they were working fine but then I did some cable cleanup (zip-tying wires to the frame, adding sheathing, etc.) and now, they don't work.
I'm going to (unfortunately) recommend you remove the zip ties and move the wires back to where they were yesterday and see if you're getting cross talk between the wires of if you have a loose connection in a crimp connector.
Since that's the thing that changed between Working and Nonworking, I think that's the most likely suspect.
ALSO: Starting new threads for the same issue isn't helpful.
@alankilian Will do, if it still doesn't work, I'll probably replace the wires.
undefined TRATOON has marked this topic as solved
